Thread: Intelliflo priming dry...except it's not
    Sep 2013
    2
    I have owned a pool service/repair biz for almost 9 years, so I am moderately competent.
    I have had trouble with the Intelliflo 011013. This was the top unit 5 or 6 years ago. They are the moodiest pumps I have ever dealt with. The 011018 is a beautiful machine, but the 011013 is a constant battle.
    I have a unit that shuts off and has an alarm "priming dry" display. The pot has 90% or more water flowing in it and the pump just stops and says priming dry after 30 seconds to a minute.
    No air leaks, no blockage, filter pressure is ok...ggrrr
    I am wondering if there is a way to bypass the unit so it runs without shooting off 15 different alarms. Just work!!!!...or if there is a solution that I have not found yet. Ready for questions and responses... Thank you
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Intelliflo priming dry...except it's not
    Sorry, I have no clue, I just wanted to say welcome to TFP. We have a service guy or two around and members that answer pump questions a lot, so maybe one of them has seen this before.
    Essential Links:
    22,475
    Do you know any of the specs on the motor itself? I tried to look them up and didn't have any luck.
    If it's a 230 volt 3-phase motor you should be able to buy a small separate AC drive and run it off that.
    Sep 2013
    2
    Thanks for the welcome.
    it is a multi speed motor, digital display with every sensor known to man. Priming dry, over current, blocked line, etc. I don't want to block all these features, but I need to tell the darn thing to let it prime.
