Results 1 to 13 of 13
Thread: CYA Question
    Fort Worth, TX
    83
    CYA Question
    I started last weekend trying to balance my pool after years of neglect.
    Here are my present readings, for what it's worth:
    FC 11
    pH 7.1
    TA 80
    CYA 20
    CH 1,100 - Yes I know it's a problem.
    This post is about the CYA.
    I started with 0 CYA according to my local pool store's test.
    I added 4 lb of HTH Stabilizer and Conditioner, Sunday before last. It was dissolved by last Tuesday or Wednesday.
    This past weekend it measured 20.
    Today it still measures 20.
    4 lbs should have brought it up to near 50 by today.
    Should I add more? I don't want to fooled by a delayed reaction and wind up with too much.
    I was really careful with the black dot test. It's a little subjective, but my wife and I both tested it and came to the same result.
    10,000 gal / Plaster / Cartridge Filter / 1 1/2 HP pump motor/ TF-100 test kit.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: CYA Question
    I wouldn't add anymore yet. I agree, if your pool is 10000 gallons (how certain are you?) then 4 lbs should have raised it close to 50 ppm. How did you add the cya?
    Jun 2011
    Long Beach, CA
    2,790
    Re: CYA Question
    How did you add the CYA to the pool? Are you measuring it in bright sun with your back to the sun and holding the tube around waist level?
    Fort Worth, TX
    83
    Re: CYA Question
    I'm certain the pool is 10,000 gal. +- 200 gal.
    I put the CYA in a sock and put it in the skimmer.
    I did the test in the shade on my patio. My face was to a cloudy sky. I held it at waist level.
    I still have the solution. I'll go do it again with my back to the Sun.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: CYA Question
    Have you cleaned the filter since adding it?
    Like ping said, redo the test with the sun out but at your back.
    Fort Worth, TX
    83
    Re: CYA Question
    No. I haven't cleaned the filter. It needs cleaning but I have purposely avoided doing it until the CYA had a chance to show up.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: CYA Question
    Good, just checking to make sure you haven't lost any that way. Do you have an autofill? If you do it could be hiding a leak and that could be diluting your cya.
    Fort Worth, TX
    83
    Re: CYA Question
    I'm the autofill. I add about 3/4" a day or more. This is a hot Texas Sun and there is a lot of evaporation. There may be a small leak, but I am not aware of it.
    38,364
    Re: CYA Question
    Your solution may be too old by now to re-look at it. Only good for 10-15 minutes I think after you mix it.
    If you do it again, realize you can pour it back and forth a few times to see if you keep getting the same result.
    Fort Worth, TX
    83
    Re: CYA Question
    I'll wait until tomorrow with a full Sun to retest it- new solution.
    Seanhan's Avatar
    Mar 2013
    Fort Worth Texas
    300
    Re: CYA Question
    You can also use instant conditioner , its kinda expensive ..but 1 gallon will raise mine exactly 10 points.
    And you can see the results on your CYA test in about a hour.
    Sean Hannon
    30,000 Gallons gunite pool Coated by Fibertech
    Hayward Pro Grid 72 / Hayward multiport
    Circupool V3 VS pump
    CirCupool SWG RJ 60, 400.000 btu raypak , Built in SPA
    Fort Worth, TX
    83
    Re: CYA Question
    Thanks- I might try that.
    I would need about a quart to bump mine up 10 points.
    I think 1/2 gallon is about $14.
    If mine hangs in at 20, I'll buy some.
    Seanhan's Avatar
    Mar 2013
    Fort Worth Texas
    300
    Re: CYA Question
    Also the instant conditioner does not mess up your PH.
    Sean Hannon
