Results 1 to 8 of 8
Thread: Winterizing Blower - Why such difference in price
    May 2013
    North East Ohio
    959
    So I've tried searching and could not find an answer...
    I am planning on my first winterization...going to do myself. And I know I need to blow out the lines...I see many people use Shop Vac like the link below.
    http://www.lowes.com/pd_127133-20097-5872411_0_
    However, why does a dedicated pool blower http://www.amazon.com/Air-Supply-Cyc...productDetailscost so much more, for yet an even smaller HP motor ?
    If I have a compressor and a shop vac that blows - is that all I really need - what advantages would the "Air Supply" unit provide me.
    If it matters, I have 2" lines everywhere - with 6 spa jets(returns) 3 regular returns, skimmer and dual main drains.
    Thanks in advance!
    14,750 GAL IG Fiberglass (16 x 33) NE Ohio || Jandy 1HP 2 speed Pump || Waterco MultiCyclone 16 Centrifugal pre-filter (removed due to not working with sand filter) || 30" 575 Lb. Sand Filter || AquaCal 140K BTU Heat Pump || Solar Cover || Inter-fab Adrenaline Slide || GLI Monsoon Solar Cover Reel || K-2006C Test Kit || BBB with Liquid Chlorine Stenner Injection || Rayner Mighty Mesh Winter Cover
    22,553
    Re: Winterizing Blower - Why such difference in price
    The blower produces more pressure than a shop vac will. If you have to blow the main drain you may need more pressure than a shop vac will supply. The blower also produces more volume than a air compressor will and that's required in some installations to make sure you get all the water out.
    ship of fools's Avatar
    Nov 2011
    Albany, NY
    496
    Shop Vac won't supply enough pressure for my main drain ... i need to use an air compressor.
    21,000 gallon inground
    Haywood Sand Filter
    Vinyl Liner
    May 2013
    North East Ohio
    959
    Ok....thanks for the feedback...it looks like I gotta buy something else. I guess though I could try my compressor and shop vac first...
    Nov 2011
    Albany, NY
    496
    Quote Originally Posted by toofast
    a regular air compressor works fine for me
    Haywood Sand Filter
    Vinyl Liner
    Quote Originally Posted by ship of fools
    I see you have 21,000 gal.. how deep are your main drains? We are doing our own close this year, have a shop vac & an air compressor... but my husband's friend swore up & down he HAD to have this other contraption. Our deep end is 8 feet - could that have anything to do with it???
    28,600 gal, IG vinyl, St. Louis, MO - Installed: 09/2012
    Pump: 1.5 hp Pentair Challenger, Filter: Pentair TR-100 sand, SWG: IntelliChlor (Pentair) Vac: 2-wheel The Pool Cleaner, Test Kit: TFT100 kit, Salt Test: Taylor sodium chloride drop test.
    Nov 2011
    Albany, NY
    496
    Quote Originally Posted by Cathy9887
    nope ..... my deep end is 8 feet or so as well
    i use an air compressor and duct tape to secure it in the piping .... that is use # 10,005 for duct tape
    Haywood Sand Filter
    Vinyl Liner
    Feb 2012
    Maryland
    400
    I have the 3HP Cyclone Vac, I just did a test and hooked it to my skimmer gizmo. I closed all valves with the exception of the MD, turned it on and within seconds I had an eruption of water bubbling out of the deep end, the water looked like it was boiling! If you can afford the Cyclone, go with that!
    I actually bought mine to put my liner in, so it saved me a ton there (thousands) and now will save me with winterizing!
    DIY 18x36 IG Vinyl Rectangle with 2 foot radius; Steel Walls. 8' steps w/t 2 step jets; 2 MD, 1 Skimmer, 2 returns; Hayward Pro Series 24 Inch 300# Sand Pool ; Hayward color logic 4.0 LED light; 2" PVC pipe 4 Jandy Valves, Hayward PL-P-4, SWCG
