Results 1 to 7 of 7
Thread: Daft questions
    May 2013
    Cyprus
    159
    Daft questions
    Hi
    I was recently told that I should rotate the multi valve handle only clockwise I was going in both directions to your knowledge is this correct.
    Also when you backwash you do so to waste when you rinse does this go to waste also, if not why can you not go strait to filter.
    Niggling thoughts need to be put to bed.
    Living in Cyprus
    Still enjoying life
    Jeetyet's Avatar
    Jul 2012
    Florida Panhandle
    200
    Re: Daft questions
    Quote Originally Posted by bof
    Hi
    I've never heard of rotating the valve in only one direction, and cannot think of any logical reason for doing so, but, I'm not an expert either so we both may learn something.
    As I understand it, when you backwash, the normal flow of water is reversed. Instead of in at the top of the sand and out thru the laterals at the bottom, water flows from the laterals up thru the sand to wash out all the junk the sand has trapped in the top layers. When you rinse, the water once again flows from the top to re-settle the sand in the filter and flush out any remaining dirty water still being flushed out the waste line. Afterwards when you switch back to filter, flow is restored to in at the top, out the laterals, and into the pool.
    "The early bird might get the worm, but its the second mouse that gets the cheese." ~ W. Rian Adams
    Relative's IG Vinyl | 16x32 | ~18,600 gals | Hayward 3/4hp Pump | Hayward S244T Filter | Pentair Model 300 Chlorinator (not used) | Polaris 180
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Re: Daft questions
    There are a few posts here that recommend turning the valve in only one direction. The reasoning behind this has to do with the spider gasket coming out of it's groove. This does happen on some filters.
    May 2013
    North East Ohio
    959
    Re: Daft questions
    Quote Originally Posted by Charlie_R
    My pool builder told me the same thing...when I asked WHY he really had no answer other than how he's always done it.
    14,750 GAL IG Fiberglass (16 x 33) NE Ohio || Jandy 1HP 2 speed Pump || Waterco MultiCyclone 16 Centrifugal pre-filter (removed due to not working with sand filter) || 30" 575 Lb. Sand Filter || AquaCal 140K BTU Heat Pump || Solar Cover || Inter-fab Adrenaline Slide || GLI Monsoon Solar Cover Reel || K-2006C Test Kit || BBB with Liquid Chlorine Stenner Injection || Rayner Mighty Mesh Winter Cover
    22,553
    Re: Daft questions
    I'm not sure it's required, but I always turn mine the same direction. That's more due to the natural progression of settings than anything.
    When you rinse the sand, the water flows through the sand in the normal direction but exits out the waste port in order to rinse any debris out and not return it to the pool.
    Jeetyet's Avatar
    Jul 2012
    Florida Panhandle
    200
    Re: Daft questions
    Interesting! Thats the first I've heard of turning the valve in one direction only. Don't think that would help me at this point as I've been going both ways for over a year now since I started looking after the pool, and the owner's never mentioned anything about it so they probably weren't aware of it either. Still doesn't pass the logic test, for me, but... I guess I'll dig a little deeper into the subject and see what I come up with.
    38,547
    Re: Daft questions
    I have heard that as well ... and tend to do it myself. Although I try not to move mine much since I am pretty sure my gasket is messed up and if I am not careful end up draining the pool out to waste
