Thread: Cracks in my pebble tec surface - pictures attached
    Aug 2013
    Southern California
    9
    Hello,
    I drained our pool to change out the water and also install a salt water system. When the pool was drained we discovered 4 different cracks in the surface and a hollow spot. All but one of the cracks looked dry, but one has remained wet for over 12 hours (pictures attached).
    Is this likely from water still seeping out of the crack that leaked in when the pool was full? I haven't noticed major water loss when the pool was full. Just the occasional top off that I attributed to evaporation from our very hot summer. How repairable are these types of cracks and what can I expect to pay?
    Any thoughts?
    Thank you!
    Mike
    15k, inground
    Apr 2013
    Sacramento, CA
    2,769
    Re: Cracks in my pebble tec surface - pictures attached
    Wow how old is this pool? Do you have pictures of this area during construction? Have you talked to PB ? To Pebble Tec?
    What do they say?
    This appears structural, but one needs to be there to make that call
    Aug 2013
    Tucson
    56
    Bump.
    Any update
    Old: 50 gallon bathtub, white fiberglass. Single drain. Faucet and "rain" feature. Elbow grease cleaning system.
    New: 28x15', 11.5K Gunite, 480 sqft cartridge filter, Pebble Fina Grigio, Glow-in-the-dark accent tiles. 30' Negative Edge. Aquabot Turbo T-Jet Robot. 0 sq ft pool deck. TF-100. Tucson Pool Build
    30,431
    +1 what gwegan said.
