Results 1 to 9 of 9
Thread: A little chemistry help
    Jul 2011
    Southwest Indiana
    61
    New pool owner .... been up and running for about 2 weeks and I am still trying to get everything lined out and functioning precisely.
    FC 6.5
    CYA 75
    PH 7.8-9
    TA 220
    salt 3300
    Water is crystal clear but obviously the TA is out of whack and FC needs to be brought down a hair.
    Just making sure before I do anything ..... looks like I need to add about 108oz of muriatic acid to bring the PH down to around 7.2 which should in turn lower the TA?
    I also lowered the % of the SWG and will let it run a few days to see if further adjustment is needed.
    19600 gallon 18x36 IG vinyl liner over full length steel steps. 4'x8' sun ledge. Sport bottom 3.5-6.5'.
    Hayward equipment including SP3200 VSP, Pro Logic, T-15, S210S sand filter, 140k Heat Pump and Colorlogic light.
    Under track auto cover.
    38,251
    Re: A little chemistry help
    Sounds like a good plan to lower the % output (or shorten the pump run time) to lower the FC a bit.
    And then just keep an eye on the pH and keep it in the 7s, as you add MA that will slowly lower the TA which should slow the rate of pH rise. Or you can get more aggressive to Lower Total Alkalinity faster.
    Jul 2011
    Southwest Indiana
    61
    I assume MA is MA ....? the Lowes web site shows this:
    http://www.lowes.com/pd_206474-34228-CR ... Id=3024039
    Work?
    Jul 2011
    Southwest Indiana
    61
    I run my pump for much longer than what I really need to ..... 12 hours a day ..... but the power consumption of it is ridiculously low. I have a lot of trees surrounding the pool and want the water moving to keep the surface as clean as possible.
    I might try running the pump at 1500rpm for 6 hours and then lower it to 1000rpm for 6 more hours .... when running that slow the SWG is disabled.
    Only a couple more weeks of swim weather around here so the bulk of experimentation might happen next spring.
    38,251
    Yes all muriatic acid is the same ... BUT, be sure to check the strength. Lowes around here have the 2 gallon boxes for sale in the pool area, but have switched to 14% stuff for the same price. Make you sure get the 31%, this is actually one thing that I usually buy at the pool store as they are competitive.
    Jul 2011
    Southwest Indiana
    61
    Lowes site says 31.45% .... hope my local store has it in stock. Pool store is a 20 minute drive.
    btw .... thanks. This site is great.
    38,251
    You may have to look in the paint area to find the 31% stuff. I have not seen it in the pool area any more, but honestly have not gone searching the store to find it.
    Jul 2011
    Southwest Indiana
    61
    Curious as to how important the TA is?
    I added some MA and it brought the PH down to 7.2 and the TA down to 190.
    Here is what I currently have:
    FC 7
    CC 0
    CH 250
    TA 190
    PH 7.2
    CYA 75
    I have been leaving the cover closed when not in use simply because the leaves are just beginning to fall ... I assume that is why the FC inched up just a bit. I adjust pump run time down to 8hrs.
    Do I do anything further about the TA or just keep an eye on it and the PH over the coming days?
    38,251
    As I stated before:
