Thread: Issue with Cleaner Pump starting intermittently
    I have a Jandy RS6 controller and a Jandy Aqualink 6614/6615 Outside PCB Box. I have had numerous issues over the last 2 - 3 months.
    Here is a summary:
    1. Pool Pump would not turn off - I replaced the relay and this problem was solved.
    2. Cleaner Pump would turn on intermittently, even when pool pump was off - I replaced the main PCB and cleaner pump relay.
    The cleaner pump issue still exists. I disconnected the inside control panel and the cleaner pump started again. I have heard that a bad spa remote (4 button control pad mounted in spa) could send ghost signals to the pcb. I also heard that a dip switch on the pcb may not be recognized. Does anyone have any thoughts on either of these possible remedies? I am pretty frustrated at this point but I am determined to find the cause for this ongoing headache.
    Thanks in advance.
    22,539
    Re: Issue with Cleaner Pump starting intermittently
    Have you unhooked the remote to see if that solves the problem?
    Have you powered the unit down before changing the dip switch?
    Bama
    I will try to disconnect the spa remote tonight and see if that solves the problem. Then if that doesn't help I will try to address the dip switch. I was wondering if either of these made sense or if there is something else I can try?
    Thank you
    22,539
    They both make sense and since they're easy to try, that's where I would start.
