Thread: brush then vac, vac then brush, or what
    Jul 2012
    Whidbey Island, WA
    397
    Sequence of brushing and vacuuming
    brush then vac same day?
    vac then brush same day?
    brush one day vac the next?
    vac one day brush the next?
    or makes no difference
    thank you
    IG under fir trees and one cherry surrounded by grass built in 1979, 30k, plaster, old Sta-Rite HRPB30, 4.9 sq.ft, 20 GPM/sq.ft., but with new glass, new (in 2012) 1 HP WhisperFlo one speed, new (in 2013) Rainbow tab chlorinator attached at the top, old Maxi-Flo Heat Exchanger MF-260, Burnham V7 oil heater 245 MBH, new (in 2012) Compool to Easytouch, Taylor K-2005 and TF-100.
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    Re: brush then vac, vac then brush, or what
    I would say it depends... if the water is clear with debris on the bottom... vac then sweep. If the debris is floating in the water... filter, but vacuum if you think you have floor debris. If you have mainly large debris/leaves, sweep, settle, then vacuum
    -- Guy --
    Smykowski's Avatar
    Sep 2011
    3,065
    I've found that I need to brush then vac same day but with a little time in between. Let's the stuff I brush settle to the bottom.
