Thread: Spa Side Remote?
    Spa Side Remote?
    Good evening to all. I'm a new member and am attempting to help my youngest who just bought a new (used) home that has an inground pool/spa with all Aqualink.Jandy controls, etc. ( im guessing it's all about 8 years old) The main control panel and inside the home one touch all work fine. The spa side switch didn't work so I downloaded the manuals and did some research. The 6 terminal brown connector inside the main control box has nothing hooked up there. Clearly, the spa side remote can't work if it's not hooked up! I dug around the wires and found a black cable that is not hooked up to anything, but this cable only has 3 wires in it, so I doubt that could be from the switch. No other unattached wires are there that I can find?
    Is there any way to test the 6 terminal brown/section of the PCB to verify that a properly working Spa Side remote would actually work? For example....connect terminal 6 and 4 briefly to see if the light turns on, etc.
    Since the remotes are over 200.00, it would be nice to know that buying a new one will, in fact, fix the problem. I could see the previous owner disconnecting a bad remote, but I can't figure out why the only apparent unattached cable only has 3 wires??? RED, BLK and BLUE with no connector on them.
    The manual shows the color wires that should go to the brown terminal, but no indication of what those color/terminals control.
    I thought about prying the switch off the spa wall and then blowing some air down the 1" pvc pipe that carries the 3/wire cable I talked about to see if that cable is the one that leads to the spa. If it is, I would be at a loss as how a 3 wire cable is there!
    note: I did purchase the actual terminal that the remote wires screw in to and then pushes on to the PCB.
    Thank You for any assistance!
    above ground intex splash pool 15 diameter, 36 deep. Approx. 4000 IMP Gallons 4750 US Gallons. 2 'cheapo' cartridge filter pumps. Heath Robinson Set-up central heating circulating pump pushing the water through 6 old radiators
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: Spa Side Remote?
    Welcome to TFP!
    I know this is an older post and no one answered it, but wanted to encourage you to continue to post and ask questions. Not every question gets an answer, but we should have at least welcomed you to the forum.
