Thread: closing pool this week but my water balance is a little mess
    Sep 2013
    indy
    15
    my levels are th- 600 ph-7.6 tc-5 ta-150 cya 80 will this be ok, next year im going to switch over to swg so I will need a little higher cya
    13500 gal , above ground 24 round 52 deep, vinyl, 200lbs sand filter,, 1.5 hp one speed, aqua trol-rj
    38,537
    Re: closing pool this week but my water balance is a little
    Well, those appear to be pool store or test strip numbers anyway, so they are all suspect.
    Order one of the Recommended Test Kits before you open next year.
    What is your water temp? We do not recommended closing until the water is staying under 60 degrees ... have you read this?
    pool-school/winterizing%20and%20closing%20your%20above%20group%20pool
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Quote Originally Posted by tlblack
    No, you won't need higher than CYA 80 with salt. Cya 80 is high limit for SWG's.
    If you close too early... >60 degrees, a whole lot more Algae will grow that you'll have to deal with next year.
    Essential Links:
