Results 1 to 14 of 14
Thread: where do u get your chemicals?
    Where do u guys order your chemicals? Local or online. If online, what companies are reputable? Anyone know a trustworthy pool supply around new Orleans?
    New Orleans, LA
    38,252
    Re: where do u get your chemicals?
    Welcome to TFP!!!
    What chemicals are you looking for? Everything you need can be found at Walmart and/or hardware stores.
    pool-school/recommended_pool_chemicals
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    Since I maintain my pool with chlorine, muriatic acid and conditioner(CYA); I get the vast majority of my pool chemicals from either Walmart or Home Depot with some liquid chlorine from the pool store since it is stronger and easier to tote.
    -- Guy --
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Welcome to TFP!
    I too get mine at the above mentioned places. Dollar store bleach is hit and miss, so try buying it only where it moves quickly. Muriatic acid is often near the paint section in most hardware stores.
    Stabilizer, (CYA) is usually in the pool section at Walmart and Hardware stores too.
    Essential Links:
    OK. I am asking because few people have told us to stay away from products at Walmart or Leslie's. Thanks
    New Orleans, LA
    38,252
    Well it depends on the product ... but most are equivalent. Is it the pool store telling you buy their more expensive products?
    In any case, if you read through Pool School you will quickly see how to save yourself time and frustration by testing and maintaining your pool yourself.
    gtemkin's Avatar
    Jun 2008
    Seattle, WA
    738
    Stay away from the pool aisle at Walmart and pool stores- with some minor exceptions - but do head over to the baking aisle if you need baking soda (sodium bicarbonate) or the laundry aisle for bleach (sodium hypochlorite) or borax (20 Mule Team) or soda ash - also known as washing soda (sodium carbonate). About the only thing you ever need to use that you must go to the pool aisle for is chlorine stabilizer (cyanuric acid, CYA). Almost everything else in the pool aisle is pseudo-magic potients that can cause more harm than good to your pool and to your wallet.
    21K gal 16' x 40' in-ground pool built 1959, old school with Jacuzzi bronze pump, American Products 24" Sand Filter & Americana Multiport valve, Jandy Lite2 millivolt heater, Coverstar cover, and classic Kreepy Krauly.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    It is fine to shop anywhere as long as you know what is in the product you are putting in your pool. For example walmart cyanuric acid (cya...aka stabilizer/conditioner) is pretty popular on here due to its price. Bleach at walmart is sometimes well priced, etc.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Quote Originally Posted by linen
    It is fine to shop anywhere as long as you know what is in the product you are putting in your pool. For example walmart cyanuric acid (cya...aka stabilizer/conditioner) is pretty popular on here due to its price. Plain Bleach (never get splashless or scented) at walmart is sometimes well priced, etc.
    +1
    It's all about understanding what the chemicals are for, and what effects they have when you add them.
    Essential Links:
    thanks! i have definitely read pool school a few times..Its great! just want to make sure i am putting the right things in.
    New Orleans, LA
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    I am of the opinion that several of the HTH products sold in my Wal_Mart are pretty good choices for many users. BUT.. the labeling on their product stinks. It rarely tells you exactly which form of chlorine is inside the package.
    Many of the items are CalHypo based so they cause less issue than the dichlor/trichlor equivalents.
    The 6-way test kits actually measures CYA (only easily retail-store obtained test kit with CYA test).
    The HTH paperwork specifically suggests you keep your CYA in the 30-50 range.
    The CYA sold is pure CYA, no filler
    The Liquid Chlorine is fair price and my store can barely stock enough so it's always fresh.
    -- Guy --
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Also watch out on the HTH dry chlorine products as many have contained copper in the past, this is the main warning against Wal-Mart pool chemicals.
    Personally when I need to buy pool specific chemicals I try to buy them at Lowes, otherwise it is mostly bleach, my family owns a janitorial chemical supply business so I get it from there at near cost.
    Donldson's Avatar
    NW Ohio
    2,881
    Just make sure to read the label, if there is no label then put it back. Seems HTH has mostly switched out the copper in their "super" products for zinc. Maybe too many complaints?
    As long as you know what is in a product, and it is what you want, the stuff from Walmart is just fine. I use HTH 1-inch trichlor (pure trichlor, no metals) for my vacation floater, and HTH stabilizer. As far as I can tell their products are as good (or as bad) as anyplace else. It can be more difficult to find out what is in a product if you buy online, so buying from a store where you can read the bottle isn't a bad thing.
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    Arch Chemicals (Lonza) is huge. I just looked and this is what I found about the Arch "brands"
    Arch Water Treatment Products Worldwide
    We are a world leader in water sanitization through our Water Products business. From municipal drinking water and food processing industries to commercial and residential swimming pools, you’ll find our products keeping our water clean and safe.
    Our well-known and popular brands – BAQUACIL®, BAQUASpa®, Being®, Brilliance®, HTH®, POOLIFE® , Pool Breeze®, and Pulsar® – are recognized around the globe.
    http://www.archchemicals.com/Fed/Corpor ... /water.htm
    -- Guy --
