Thread: Need an advise from those with auto cover
    Azmp1's Avatar
    Jul 2012
    Maryland
    283
    Hi All,
    So when my auto cover track was installed and subsequently everything else finished, plaster, grout, etc, one thing thing that was not done, it the line where the track sits on top of the tile is not 100% flush with the tile and has some spacing in some areas as it was never grouted or caulked... I asked both the builder and the autocover guys about it and both said it was fine, but i'm worried as I can definitely see water getting in there. Not a big gap, maybe 2-3mm in some areas, but still....
    19200gl rectangular gunite/diamondbrite perl pool || Coverpools auto cover || Jandy variable speed 2hp e-pump & Polaris PB4-60 booster pump || Polaris 3900 sport cleaner || Jandy CV filter || Jandy AqualinkRS8 w/Aqualink touch || Jandy iAqualink2.0 || Jandy Watercolors LED || Jandy AquaPure 1400 SWCG || Hayward auto chlorinator (backup) || Raypak 117k BTU heat pump
    Azmp1's Avatar
    Jul 2012
    Maryland
    283
    Here are the pics for reference, see the gap between the tile and the bottom of the auto cover rail.
    Sent from my iPhone using Tapatalk - now Free
    Re: Need an advise from those with auto cover
    Hi - Ive had my auto cover for only about a month but it looks very similar to yours set up and I have yet to experience any problems.
    By the way, what do you think water splashing in there would harm?
    Azmp1's Avatar
    Jul 2012
    Maryland
    283
    well that's my fear as you really don't want any water potentially getting behind the tile and the water in most definitely splashing in there with those unfilled gaps... we've been swimming since early July and no problems so far, but I wouldn't really expect any immediate issues, my concerns are more longer term.
    So, that's what I would like to find out if its a common practice to not grout/caulk or somehow seal that joint and should I be getting on my builder to get it fixed. It just doesn't sit well with me.
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,798
    Since mine is CoverStar, the track looks slightly different. The lower section, below the rope, has a plastic strip that snaps in to provide a clean covering down just below the top edge of the tiles. But there are also places where I can see grout up on top of the tile, against the track system. It does not look like yours with small gaps. However, I think the places where I can see the tops of the tiles are on the end opposite the cover pit where it's just an aluminum spacer versus a track. I'll try to get pics for reference.
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
    Azmp1's Avatar
    Jul 2012
    Maryland
    283
    Thanks. I spoke with the builder again as well as the company who installed the cover and they're both swearing that this is not an issue and the space between the tile and rail always left like this and not causing issues because the gaps are just too small for to much water to get in... i'm still not having the warm and fuzzy...
