Thread: Aluminum coping to pavers in liner pool
    Hi all, Newbie here. We inherited an older in-ground liner pool last year and this fall are underway taking up the old concrete surround and installing pavers. My question is this:
    Is there a product out there that eliminates the traditional aluminum coping and allows cantilevered paver coping, but still allows the liner to be snapped into a channel without
    needing the old style coping?
    We want to keep the liner, but switch to a paver coping.
    Thanks in advance for all your help
    Chris
    Ukie's Avatar
    May 2012
    Export, PA
    83
    Re: Aluminum coping to pavers in liner pool
    My guess you will need a new liner track(without aluminum coping) installed.
    Lagoon shape, 23,600 Gal, steel walls by International Swimming Pools, "ultra-seam" liner by Latham, Pentair 011018 IntelliFlo 3HP Variable Speed Pump, PentAir CCP420 filter, Heat Siphon Z575HP, PentAir IC40 SWG, 2 LED Lights (Pentair Intellibrite 5G, 110V). 4 x 1.5’’return lines, 2 x 2’’skimmer lines, 1.5’’ waterfall line. All plumbing is "TigerFlex" pipe, all lines plumbed individually. Deck: travertine glued over concrete.
    Ksnewman's Avatar
    May 2012
    Middle Tennessee
    173
    We had to choose the coping specifically for cantilever application.
    18x36 kidney 20,000 gallons IG vinyl. Pentair Easy Touch 8 w/IntelliChlor IC40. Triton II TR100. Pentair Intellifllo Variable Speed. Waterfall/Jump Rock. 2 Pentair Intellibrite lights. TF-100 Test Kit. And a very happy husband who gets to play in the pool without having to take care of it.
    Feb 2012
    Maryland
    400
    we too chose specific cantilever coping, its very thing and has just enough lip for the liner track
    DIY 18x36 IG Vinyl Rectangle with 2 foot radius; Steel Walls. 8' steps w/t 2 step jets; 2 MD, 1 Skimmer, 2 returns; Hayward Pro Series 24 Inch 300# Sand Pool ; Hayward color logic 4.0 LED light; 2" PVC pipe 4 Jandy Valves, Hayward PL-P-4, SWCG
