Thread: Best Year of pool ownership, thanks to the Liquidator!
    We had a Hayward inline chlorinator that was causing our stabilizer to go through the roof all year long. The pool was cloudy and just an absolute algae fest all year. Could never get the FC to register and was constantly shocking it.
    This year, after joining this site, I made the switch to a liquid stabilizer at the beginning of the season and the Liquidator. Within weeks of the installation, my wife was making comments that the pool was crystal clear and was always clean! I travel a ton with my job and the pool gets ignored chemistry wise when I am not around. The liquidator has really helped me to get it dialed in and almost "set it and forget it". I still check the chemicals, but 2x per week seems normal and usually, just require very minor tweaks (in July and August, usually our worst months, I made 2 minor adjustments).
    What has amazed me is that I have shocked my pool only 2 times since I got the liquidator (one was after having 75+ people over for a family reunion) and the other was after having my sons Little League team over. Other than that, it have been trouble free.
    Thanks for all of the recommendations!!!
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Best Year of pool ownership, thanks to the Liquidator!
    Excellent to hear a good susccess story.
    Never tire of them myself, and I'm very happy to hear it's working for you. Isn't it amazing how easy it is?
    Essential Links:
    The hardest part was getting it plumbed in correctly. I installed the float valves upside down and realized it before it came pouring into my garage!! Once that was corrected, it was simple!
    I go through about 2-3 gallons of 12% "shock" chlorine per week. It is crystal clear right not, even though it does need a good vacuuming as the leaves are falling. Pool still warm at around 83-86.
    jcowart's Avatar
    Jun 2012
    Labelle, TX
    320
    Quote Originally Posted by bigdaddy72
    That's not bad for your size pool. Looks to be about 13ppm a week with a little less than 2ppm a day. I just can't find anything in my area above 10%. Did you run into any of the common problems? Bubbles in the tubes, white stuff, things like that.
    17500 gallon Doughboy AGP, Hayward DE filter, waiting for the 1.5hp DB pump to go out.
    Learn to take the advice here and be trouble free or use the pool store's advice. "You can't do both and get very far"
    No major issue. Just one annoyingly noisy check valve. I probably will be closing it either this Sunday or next sunday. Still crystal clear even with a few leaves floating on the bottom.
