Thread: water loss. Evaporation/splash????
    Western KY
    36
    This is my second year with a pool. I have an 18 X 36 19,000 gallon inground pool. I Live in Western Kentucky where it is very hot and the humidity is high. I am experiencing what seems to be a lot of water loss. Maybe 1" to 2" per week. I dont remember having this issue last year, but I cut down several trees last fall so the pool sees a lot more sunlight. The pool has seen more action this year as well. Could this be an evaporation and splash out issue or do I have a leak? What is normal water loss due to evaporation?
    Thanks
    20,000 gal. Vinyl
    1.5 hp pump 300 lb. sand filter.
    sammm's Avatar
    North Richland Hills, TX
    257
    Re: water loss. Evaporation/splash????
    Get a 5-gallon bucket of water and place it near the pool. Top off your pool at the same time. Mark/note the water levels on both. Watch to see if the bucket loses water at the same rate as your pool. I just went thru the same thing and it was evaporation. Sun, wind, water temp will all come in to play.
    WetEdge Satin Matrix, 16K gallon, Pentair NSP-60 DE filter, Pac Fab Challenger, 2HP pump, BBB, Polaris 360
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    If you don't use a cover, and you have more sun exposure that is certainly normal to lose a lot with evaporation, especially if the weather conditions are "just right" to see evaporation (no rain, warm, arid) plus combine it with swimmers/splash out....
    Mar 2007
    Coastalish 'down easter'
    4,160
    There is a discussion of this in Pool School http://www.troublefreepool.com/categ...leak_detection that will tell you what to look for when there's some water missing from your pool.
    Luv& Luk
    -Ted
