Thread: Pool drainage question
    Jun 2013
    Northern NJ
    123
    I have to drain my pool about 48% according to the pool calculator on order to reduce a very high cya. Using my wate setting on my Haywood will probably take quite a while I assume. Would an additional submersible pump be a wise decision. Pool is closing on Friday. Thanks
    36,000 gal IG vinyl. Haywood pump and heater Hayward DE filter blue diamond robot. Hayward Aqua Rite SWG AQR-15
    38,475
    Re: Pool drainage question
    If the pool is closing, why are you replacing water to lower the CYA now? I would wait until spring.
    You can use the waste setting if you can isolate the floor suction, otherwise a submersible works great.
    Jun 2013
    Northern NJ
    123
    I could wait until spring. Maybe some cya will dissapate over the winter. We won't be using pool this week anyway. Thanks
