Thread: Aqua leader 23'10" j hook pool liner
    Hi what size after market pool liner can I buy to replace the aqua leader pool liner originally installed 20 years or so ago?
    I just called the store and they want over $500 for a new liner that will fit our pool. I was looking at Unibead liners that were 24' round with the j hook installation.
    WILL this fit? I also have a hopper (deeper section in the middle of the pool about five feet) will I need a 48" or 52" to accommodate that extra depth?
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: Aqua leader 23'10" j hook pool liner
    Welcome to TFP!
    I know this is an older post and no one answered it, but wanted to encourage you to continue to post and ask questions. Not every question gets an answer, but we should have at least welcomed you to the forum.
    Does anyone have any suggestions. If I take the pool down how much could I ask for it. It is in good shape and can be reinstalled no problem.
    Thanks for any input....
    30,414
    Used pools vary so widely it is impossible even to guess. Your best bet is Craigslist and use your judgement.
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,379
    If you are still looking for a liner, have you thought of trying an expandable overlap liner such as this one?
    Love TFP? Become a
    TFP Supporter!
    Oct 2013
    7
    It sounds like you have a fitted (custom) liner). I would go with the 1st option, especially if it is guaranteed to fit (if its the same as the original it should fit just as well as the original - maybe even better, depending on your skill as an installer.) Anything else provided by an alternate vendor will be hit or miss unless you provide them actual measurements. Even then the ultimate responsibility for a good fit will be on you and your tolerance for perfection versus wrinkles.
