Results 1 to 9 of 9
Thread: 150 inch pounds !!!
    Seanhan's Avatar
    Mar 2013
    Fort Worth Texas
    300
    150 inch pounds !!!
    New Hayward ProGrid filter says to tighter the band bolt to 150 inch pounds.
    There are no springs over the bolts like the old filter had.
    I was looking for a tourque wrench and the ones i can find are all foot pounds .
    I think 150 inch pounds is around 12-14 foot pounds ?
    The wrenches i found all start at 20 foot pounds ..
    What do you use ??
    Sean Hannon
    30,000 Gallons gunite pool Coated by Fibertech
    Hayward Pro Grid 72 / Hayward multiport
    Circupool V3 VS pump
    CirCupool SWG RJ 60, 400.000 btu raypak , Built in SPA
    Seanhan's Avatar
    Mar 2013
    Fort Worth Texas
    300
    Re: 150 inch pounds !!!
    Looks like 150 inch pounds is 12.5 foot pounds
    Sean Hannon
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    There are 1/4" and 3/8" drive torque wrenches that are calibrated for that range. They can be hard to find. You may have to contact a Snap-On, Mac or Matco tool dealer to find one.
    38,343
    That is not much torque, I would just snug it down.
    Seanhan's Avatar
    Mar 2013
    Fort Worth Texas
    300
    I found a torque wrench at harbor fright ... Had to get a 3/8 inch drive . They go from 5-80 lbs
    Filter said 12.5 lbs so i used 15 lbs ..
    Yea its not much .. But Hayward attached this big plastic coated tag with steel cable to the bolt ..
    WARNING SEPERATION HAZARD Kinda scard me !!!! i had a old Anthoney Apollo blow one time and it Launched like the space shuttle !!!!
    Sean Hannon
    Jan 2014
    Buckeye AZ
    807
    ugh, yeah, just went to lowe's and it's 50-250 found pound wrenches. which, kinda glad because those are $75. I think there's a harbor freight on my way home.
    I am also resuscitating old threads this week as I do this stuff for the first time.
    10,500 gal IG, Topaz Pebble, auto-level
    Hayward DE filter, 2HP Ecostar VSP, ProLogic PS-4, GVA actuators
    Cal Pools Wave Force Plus (wall return jets plus 2 floor pop-ups), Venturi Skimmer
    Water sheer, 2 wok pots, bubbler stem on the baja step
    ColorLogic Mutlicolor LED lamp. Taylor 2006+speed stir
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    auto parts stores are a good source for small torque wrenches too.
    Divin Dave,
    JayBauman's Avatar
    Sep 2014
    Katy, TX
    617
    I used my (only) torque wrench that I had from when I did my own motorcycle maintenance. I bought it at Sears circa 2001. I only had to divide inch.lbs by 12 to get ft.lbs, which was well within the range of my tool. I think I paid about $80 for it back in the day, so it's kind of an expensive option for ensuring "optimum" compression on the filter band clamp. Not sure I would invest in one if I didn't already own it.
    And to all of our friends in Europe, Asia, Canada, and Latin America....I'll speak up and apologize for the use of barbaric units in this thread.
    23' x 37' IG 18.5k gallon SWG w/ raised spa, Build Thread -->Here
    Wet Edge® Pearl Matrix®, Hayward® SwimClear™ 525 ft², Hayward® Goldline Controls® PS-8
    4x Hayward® TriStar™ pumps, Paramount PCC2000® ICS, TF-100 w/Speedstir
    Mar 2011
    441
    I can't say I, or anyone I have ever worked around has used a torque wrench on pool equipment. Typically we use 4 types or criteria when tightening a nut or bolt. Barely tight, snug, super snug, or as tight as you can get. Knowing which one to use and where is the trick.. I would just say to get it snug and you should be ok.
    20X40 30,000 gallon gunite pool
