Thread: Pool Closing and the Liquidator
    Ellington, CT
    262
    This has been my first year maintaining my pool using the TFP methods. I started out of the box using the Liquidator and once I had it dialed in, found it very easy to maintain my pool. So now it closing time here in CT and I normally disassemble my pump and filter and store the parts in my shed over the winter. This being the first time that I will need to tear-down the Liquidator I wondering how other people go about emptying it? Do I stop putting chlorine in it and let it continue to run then somehow empty it into the pool? Any advice and best practices would be much appreciated
    Regards
    Rich (laprjns)
    30,000 gal, 20 x 40 ft vinyl, IG, installed 2006
    1 HP WhisperFlo pump, 60 sqft Pentair Quad D.E., Liquidator(8 gallon) with 3/8 upgrade, AquaVac TigerShark cleaning robot
    TFTestkits TF-100 with SpeedStir, WS
    A proud practitioner of TFP since 2013
    22,553
    Re: Pool Closing and the Liquidator
    Since you need to bring the pool up to shock level before closing it anyway, I would open the LQ valve all the way and let it empty the bleach out of it. I also used to take a section of tubing and hook it to the suction fitting in the plumbing and drop the end of it in the LQ and close off the inlet and let the pump suck most of the liquid out of the LQ. That way you don't have to handle as much water.
    Ellington, CT
    262
    Thanks, that makes sense.
