Thread: What a dye test looks like.
    X-PertPool's Avatar
    Exeter, PA
    1,385
    I made a video showing what to look for when using dye to locate a leak. When there is a leak the dye does not hang around or cling to a surface or edge, it gets sucked right into the void.
    [youtube4940tkk]HgrvM7DBgTQ[/youtube4940tkk]
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    X-Pert Pool on Facebook and @XPertPoolServic on Twitter
    22,000 gal / 16' x 32' / Vinyl / Hayward s244t /Pentair SuperFlo 1 hp
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Re: What a dye test looks like.
    Thanks for doing that!
    30,431
    Excellent! What type dye did you use? I used food coloring and it spread and diluted into the surrounding water too quickly. It wasn't nearly as useful as what you are demonstrating.
    Thanks for posting that.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Yea, this was interesting to watch. Appreciate you showing it to us.
    Essential Links:
    Butterfly's Avatar
    South Carolina
    10,045
    Kevin
    You're done SLAMing when:
    X-PertPool's Avatar
    Exeter, PA
    1,385
    No problem. The dye I used is a black gel food dye that I found at a local restaurant supply store (http://www.mainesource.net/) mixed with water. Basically as I squirt it underwater it refills with water and becomes diluted over time. So when it becomes too diluted I add a few more drops of the gel. This is the dispenser http://www.usplastic.com/catalog/item.a ... &catid=535
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
