Thread: chlorine tablets available without cya?
    Jun 2013
    Saskatoon, Saskatchewan, Canada
    40
    Can you buy tablets for a spa sized floating feeder that just contain chlorine without cya?
    16' x 48" intex ultra frame above ground pool 5000g
    one speed Filter Pump with 1,500 gallon (5,678 L) per hour flow rate
    340g FreeFlow Solstice Spa, 1.5 hp two speed pump, 50 sq ft. filter
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: chlorine tablets available without cya?
    No, there aren't such chlorine tablets for a spa -- there are Trichlor tablets, but they dissolve too quickly in the hot water of a spa. There are some products that use Trichlor in special feeder for spas but many spa manufacturers void their warranty if you use them mostly because you can get the pH too low if you aren't adjusting it regularly. For spas, there are bromine tablets you can use in a floating feeder, but that is, of course, bromine.
