Re: Why is my Autopilot Digital Nano unhappy with pump spefl
LovrPool, as mark asked, when the pump is turned off, does the manifold base check valve fully shut? You should be able to see the Red Gasket on the inlet side of the check valve. Using the plastic on the screen is the way to clear it out, if there were debris, but you should verify that it is opening upon higher flow, and fully closed when turned off. The Flow switch is actually rated for 15 gpm, and I just feel safer to say 20 gpm, so with the flow characteristics of your varible speed pump, you should have enough flow at 1000 rpm, but it really depends on the actual going through your system.
First, the check valve after the heater is not necessary. There is no residual chlorine generated by the manifold assembly to worry about chemical back flow to the heater.
Second, there is a check valve with a built in flow meter made to retrofit into a Jandy valve.
http://h2flow.net/h2flow/index.cfm/prod ... low-meter/
This device will verify what your flow rate is... and personally I think it's cool as heck!
Finally, the flow switch does not usually come out of "calibration" to activate at 20 gpm, but sometimes can get twisted or bent out of shape. It's possible that your PB may be able to swap out the tri-sensor to see if that makes a difference.
Who was your PB (or installer)?
