Page 1 of 3 123 LastLast
Results 1 to 20 of 42
Thread: Why is my Autopilot Digital Nano unhappy with pump speflow w
    Sep 2013
    Ohio
    38
    We just had a fiberglass pool (13,000 gal) installed (2wks ago) and we have an Autopilot Digital Nano SWG and Sta-Rite Intellipro Variable speed pump. We wanted the variable speed for energy savings however the autopilot doesn't like anything less than 1500rpms. We are "pool illiterate" and I have been so thankful for this forum and have learned a lot!!
    Is this normal to have to run the pump no lower than 1,500 rpms?
    So far We have been running the pump at 1500 rpms for 6hrs during the day and 4 hrs at 2100 during the eve when we are usually on the pool the most. Another 2 hrs at 1500 and pump doesn't run at night. (Total run time 12 hrs during the day). Temps are in the 80s during the day 60s at night.
    Appreciate any advice!!
    15'x25' 11K gallon fiberglass IG; 3HP variable speed pump, cartridge filter 150 flow rate; SWG (Autopilot Digital Nano); Mastertemp 200 heater; installed August 2013.
    22,543
    Re: Why is my Autopilot Digital Nano unhappy with pump spefl
    Welcome to TFP.
    Can you post a picture of the equipment pad? That will probably help us spot if there's something you can change plumbing wise.
    Sep 2013
    Ohio
    38
    here is a link to pic of the equipment pad.
    http://i1289.photobucket.com/albums/b50 ... 74a5b5.jpg
    mas985's Avatar
    Pleasanton, CA
    11,737
    First, fill out your signature with your pool stats and equipment list as outlined here: pool-school/read_before_you_post
    Second, answer the following questions:
    Filter pressure at full speed?
    Filter gauge height relative to pool water?
    Distance from pool to pump?
    Suction line pipe size?
    Also, you might want to check the SWG flow switch for any debris or damage.
    Mark
    Sep 2013
    Ohio
    38
    Filter pressure At full speed (3450 rpm) is at 30psi. Cleaned cartridge filter last night as well as the SWG cell filter screen (which was clean).
    Gauge height from pool water is 4'.
    Distance from pool to pump is 30'.
    Pool plumbing is 2"
    When we checked the filter screen we wrapped it in plastic and reassembled and turned the pump on to flush out any debris. How would we know of the flow switch is damaged?
    Sep 2013
    Ohio
    38
    Found how to check flow switch. Paddle is straight. Looks good.
    mas985's Avatar
    Pleasanton, CA
    11,737
    From everything you mentioned, I estimate that the flow rate should be about 40 GPM at 1500 RPM and 26 GPM at 1000 RPM so it looks like it should work fine. Are you getting decent flow rate out of the returns at 1000 RPM?
    Also, do you know the type of check valve that you have? Flapper or axial spring type. If the latter, those can add a lot of head loss to a plumbing system, especially at low speeds. What was the filter pressure at 1500 RPM?
    Mark
    Sep 2013
    Ohio
    38
    Not sure on type of check valve. Turning pump down to 1000 rpms the psi is 1. Could drastically tell a difference in the flow of the returns when went from 1800 down to 1000. At 1500 rpms it is at 5 psi.
    mas985's Avatar
    Pleasanton, CA
    11,737
    It is seems like it is one of two issues. The check valve is closing down on low speed further restricting flow rate. Or there is something wrong with the flow switch (which you have already inspected). I don't want to have you replace the check valve without knowing which type it is so is there a part # on the valve anywhere. Can you take a close up of the valve? Can you ask the PB what brand/part# he used?
    Also, when was the last time you cleaned the filter? It might be worth a try too.
    Mark
    Sep 2013
    Ohio
    38
    The check valve is the spring type. It has a sticker on it that says "3lb spring".
    We took the cartridge filter out last night and sprayed it off real good.
    Tried reducing the rpms on the pump to 1480 and the autopilot got unhappy pretty quick. It's stubborn at needing it at 1500 for the 'check flow' error to go away on the display.
    mas985's Avatar
    Pleasanton, CA
    11,737
    Unfortunately, I think the problem may be with the check valve. 3 lbs is way to strong for low speeds. The lowest head loss check valves are like this:
    http://www.zodiacpoolsystems.com/Produc ... Valve.aspx
    That type of check valve should never have been installed and I would try to get your PB to replace it with a Jandy flapper style check valve.
    Mark
    Sep 2013
    Ohio
    38
    Thank you Mark! I will see what the PB says.
    I did look at the autopilot site and this came with their system. This link shows exactly what we have in place, including the spring check valve.
    http://www.autopilot.com/our-products/c ... gital-Nano
    mas985's Avatar
    Pleasanton, CA
    11,737
    That wasn't the check valve that I was referring to. The one I am referring to is between the heater and the SWG setup and it looks like this:
    Mark
    Sep 2013
    Ohio
    38
    Oh! I will check after work. The link below is a pic of my equipment pad. Based on your pic, it looks like ours is just to the right of the heater, correct?
    http://s1289.photobucket.com/user/jrdic ... 5.jpg.html
    mas985's Avatar
    Pleasanton, CA
    11,737
    Yes, between the heater and the SWG loop.
    Mark
    Sep 2013
    Ohio
    38
    This is what is between the heater and swg
    http://www.lowes.com/pd_154372-34146-P3 ... Id=3350952
    mas985's Avatar
    Pleasanton, CA
    11,737
    That is an irrigation check valve and should never be used on a pool. Your PB should know better. That type of check valve requires 2 PSI to open which at 1000 RPM is a problem because the pump cannot generate that much pressure and still deliver the minimum flow rate. That is most likely the cause of the problem.
    If it were my pool, I would demand that he replace it with a proper check valve at no charge.
    Mark
    Sep 2013
    Ohio
    38
    Thank you Mark!!!!!! I just saw that on the lowes' site for the specs that it requires min. 2psi. Oh geez. Just sent an email to the PB to switch this out to something that is more compatible with the system we have. Thanks!!!!! This forum rocks!
    Sep 2013
    Ohio
    38
    Saw new check valve part next to equip. Not installed yet. It is a Spears 2" S1520-20 (swing check valve). Found specs online: min. Opening pressure less than 0.5psi, full flow (open) 150 psi, back pressure (closed) 75psi.
    I couldn't find specs in the jandy other than says min. Hydraulic loss.
    With 0.5psi the swg should allow me to run the pump under 1500rpms. This sound correct?
  20. Back To Top    #20
    mas985's Avatar
    Pleasanton, CA
    11,737
    I believe the Jandy valve opens at 0.25 PSI. The Spears might work ok but the Jandy has half the opening pressure and you can replace the valve without cutting into the plumbing which is a big plus. Any reason the PB doesn't want to use a Jandy?
    Mark
