Thread: Ph high - can we swim?
    Jun 2013
    Bucks County PA
    94
    Hi all! I had a low ph and used the pool calculator to determine that I needed to add some Borax. I was in a rush and "guestimated" the amount of Borax. Now my ph is 8 (or perhaps higher - it is a very bright 8.0) I plan on measuring this time - 20 ounces of muriatic acid. Two questions:
    1. How soon after adding the muriatic acid can we swim?
    2. Can we swim with a ph of 8+?
    Thanks for being there
    22Kgal (18x36 3.5-6ft), IG,Vinyl,DE 36sqft Filter -90GPM flow rate, Pentair Whisperflow Pump,SWG Intelichlor, UltraTemp Heat Pump, New 10/2012 Bucks County PA
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,621
    Re: Ph high - can we swim?
    You can swim in it, just might be a little irritating to sensitive eyes. I add MA and swim 30 minutes afterwards. Pump running of course and poured slowly in front of a return.
