Page 1 of 2 12 LastLast
Results 1 to 20 of 21
Thread: 3 Years of Algae
    Jul 2013
    Long Island New York
    63
    3 Years of Algae
    Hi all, have been battling algae for 3 years now. Always did what pool store recommended, would not see if for a few days then bam back again. Same thing all year this year until I found this site. My water looks FANTASTIC, best it has in years however....I still have not passed an overnight chlorine test. I have been slamming the pool but I suspect my trouble is behind my light. Am working on getting that out and cleaned. When I went out there this morning I did once again see a small spot of algae. Test results are as follows.
    PH 7.5
    FC 33
    CC 0
    TC 33
    TA 110
    Cyanuric Acid-80
    I have been shocking up to mustard algae levels according to the chart. First night chlorine took a nose dive, brought it back up and it lost about maybe 3 or 4 ppm overnight. I have a lot of gray stuff on the bottom of the pool that I am guessing is dead algae. Let it slack until I can get my light out, seems to be stuck then will bring it up again. Do I seem to be on the right track? My CA is high I know but I hope to get through this year (closing in two weeks) and will drain at beginning of season next year. Any advice would really be appreciated.
    TF-100 Test Kit
    16 x 36 @26,000 Gallons Vinyl Inground Built in 2005
    Hayward Pro-Grid 4820 DE Filter
    Hayward HP-2100 Heat Pro Heat Pump
    Aquabot 4WD Cleaner
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: 3 Years of Algae
    Welcome to TFP!
    Be sure to brush regularly since it sounds like you might have poor bottom circulation if you are seeing algae at high chlorine levels. Also, if your water is now clear, clean/backwash your filter if you have not already done so since dead algae in the filter will have you fail the OCLT. Also, the OCLT criteria is for regular shock level, not yellow/mustard algae shock level. You may lose somewhat more, though probably not 3-4 (more like 2). Also with your high CYA level you may also lose more overnight (chlorine oxidizes CYA). The bigger issue at this point is the visible algae so yes, get behind the lights to see if that is a continuing source for algae since you want to kill it off, especially if it's yellow/mustard algae.
    Jul 2013
    63
    Thank you for the quick reply. Just managed to get the light out as per my suspicion the back of it does have green on it. Will get that taken care of clear out its little house in the pool and bring it back up to shock levels and see where that gets me! I will also brush diligently again. I am going to pull my ladder out since right underneath that is where I saw the algae spot. I will vacuum tomorrow to get all that gray stuff out and do a backwash.
    TF-100 Test Kit
    Aquabot 4WD Cleaner
    Mar 2007
    San Rafael, CA USA
    12,082
    It sounds like you are only seeing green algae and not yellow/mustard algae, correct? If that is the case, then only SLAM to the regular shock level, not the yellow/mustard algae shock level. That should help you pass the OCLT.
    Jun 2011
    Long Beach, CA
    2,790
    If the ladder has water inside it, there could be a harvest of algae inside it. Inspect the ladder the best you can for algae and you might have to remove it once in a while to give it a good scrubbing. Algae likes to grow on surfaces that don't get brushed.
    Jul 2013
    63
    im on it thank you all very much! what should i use to kill the algae on light i took out. i was going to 100% bleach it is that ok?
    TF-100 Test Kit
    Aquabot 4WD Cleaner
    Mar 2007
    San Rafael, CA USA
    12,082
    For just wiping it or short exposure, that's OK.
    Jul 2013
    63
    i do suspect algae inside ladder thats why i will pull it out. will just wiping light down with bleach be sufficient to kill all the algae? i plan on leaving light out overnight as well to expose its case inside pool to shock level of pool water. am i on track with this plan?
    TF-100 Test Kit
    Aquabot 4WD Cleaner
    Mar 2007
    San Rafael, CA USA
    12,082
    Yes, exposing the light niche to shock levels of chlorine will be good. Leaving the light out in the water exposed to shock levels of chlorine is also good. Standard pool lights have water behind them intentionally. It's used for cooling the lamp, but the circulation is poor.
    Jul 2013
    63
    Light wasnt as bad as i thought but it did have some really dark green patches on it. bleached it let it sit for a couple of minutes then did it again. three times i did it. have robot in pool as well now letting him get cleaned up. there was quite a bit of gray stuff behind the pool light, not sure what it was but i cleaned at that area out good as well with brush. hopefully i am on the road to recovery. but with chlorine at 33 ppm this morning how come i saw a small green patch by ladder. its been fine for over a week and a half. i didnt expect to see any growth until chlorine fell way down. also with the algae behind light would it typically start to bloom by the light first or could it really be anywhere?
    TF-100 Test Kit
    Aquabot 4WD Cleaner
    Mar 2007
    San Rafael, CA USA
    12,082
    Do you have circulation by the ladder area? Can you take a sample of the green patch and see how it feels -- it might not be algae.
    Jul 2013
    63
    what would it be if its not algae? wouldnt be pollen at this time of year in new york.
    TF-100 Test Kit
    Aquabot 4WD Cleaner
    Jul 2013
    63
    interestingly enough found this growing on the back of my thermometer even after days at shock level. can anyone offer any insight?
    TF-100 Test Kit
    Aquabot 4WD Cleaner
    Smykowski's Avatar
    Sep 2011
    3,065
    Poor circulation at the thermometer. Are you brushing?
    Jul 2013
    63
    yes been brushing, but honestly neglected the thermometer. its out of the pool now and will remain out. thermometer is 5 feet from a return in the shallow end of pool. water passes it, it never hangs straight down so water has to be pushing it.
    TF-100 Test Kit
    Aquabot 4WD Cleaner
    Mar 2007
    San Rafael, CA USA
    12,082
    I presume that green feels slimy, correct? You can see what happens if you put some of it in some concentrated bleach. It may be biofilm and not just algae though the green part of it is likely algae.
    Jul 2013
    63
    what is biofilm? funny you mention that cause when i scraped it with my nail it peeled off. thought it might have been on part of a sticker on the thermometer. it did feel slimy.
    TF-100 Test Kit
    Aquabot 4WD Cleaner
    Mar 2007
    San Rafael, CA USA
    12,082
    Biofilm is what forms when bacteria excrete chemicals that protect them from the environment and becomes more chlorine-resistant as a result. Biofilm can be a combination of different microorganisms. If you kill the microorganisms before they form biofilm, then it will not form, but if a pool isn't maintained properly, especially over an extended period of time, then such biofilm has to be physically removed -- chlorine alone won't handle it (except at extremely high levels).
    Jul 2013
    63
    how do i know if i have biofilm?
    TF-100 Test Kit
    Aquabot 4WD Cleaner
  20. Back To Top    #20
    Mar 2007
    San Rafael, CA USA
    12,082
    A slimy surface that grows and is not inhibited by chlorine. Usually it's clear or light gray and not green. Green usually indicates chlorophyll so either algae or possibly green sulfur bacteria or cyanobacteria.
    Regardless of whether you have biofilm, grease, or anything else slimy on a surface the solution is the same which is to physically remove it. If you had a very serious amount of biofilm or white water mold in the pool developed over years of improper management, then you could use a powerful surfactant to help remove them, but I don't think we can conclude this yet.
