Results 1 to 10 of 10
Thread: Pentair Intelliflo VF vs VS?
    les_garten's Avatar
    May 2011
    PSL, FL
    153
    I need to get a new pump.
    I am considering the Intelliflo VF. It has been out a while. Should I be looking at another "computerized" pump?
    I think I want the VF over the VS. Has there been any issues with maintaining the motor or electronics over the long run?
    14x30 PebbleTec(Caribbean Blue) 12,000 Gals BORAX
    Pentair IntelliFlo <<>> Pentair FNS Plus DE
    Pentair 5G Intellibrite w/Intellibrite Controller
    ROME Solarium 125 Heat Pump
    Kreepy Krauly Classic <<>> Pentair 320 Feeder
    Re: Pentair Intelliflo VF vs VS?
    I have been running my VF for 18 months or so, I'm quite happy with it. It hasn't required any maintenance other than emptying the strainer.
    8.5k gallon IG pebble sheen play pool with Intellitouch control, Intellifo VF, IC 20, Rainbow tab feeder (not currently in use), Pentaire mystery cartridge filter with labels faded to the point I have no idea on the model, Intellibrite 5g LED light, Hayward Navigator. Adding IntelliPh and Crestron control next.
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Have you considered 2-speed pumps? The initial cost is considerably less compared to a variable-speed pump and it is a much simpler design. 2-speeds also have a shorter payback time (initial cost vs. energy savings) in areas where electric rates are $0.20/kWh or less.
    With that said, manufacturers are coming out with newer designs on VS pumps. Would suggest reading this article before making a purchase: A Pump Game Changer.
    mas985's Avatar
    Pleasanton, CA
    11,737
    Quote Originally Posted by les_garten
    Yes but it is generally caused by power surges so you want to make sure the pump is installed on a filtered/protected circuit. If you decide to go that route.
    Mark
    les_garten's Avatar
    May 2011
    PSL, FL
    153
    Quote Originally Posted by BoDarville
    Hi, pretty sure I want the control of the VF.
    I'd like to read that link you have there but it says I am not authorized?
    les_garten's Avatar
    May 2011
    PSL, FL
    153
    Quote Originally Posted by mas985
    I do have some surge issues with our power clipping in and out. I'll have to call Florida Power and see if they offer something
    les_garten's Avatar
    May 2011
    PSL, FL
    153
    Here is the whisperflow wet end still in place. It's glued in.
    I may be ordering a VF on Monday. Would you guys just bolt up the VF motor to the old wet end?
    If you were going to cut out the old wet end, where would be the best place to cut on my system to put in unions?
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    The gist of that article was that Haywood recently released two new VS pumps based off the Super Pump and the Max-Flo product lines. These VS pumps have a lower initial cost than most VS pumps and a lower nameplate HP (1.5 HP vs. the more common 3 HP of most VS pumps). These new VS pumps have the potential to have a lower lifetime cost than many 2-speed pumps in a shorter time period compared to most other VS pumps. Here are two links to Hayward's web site on the VS Max-Flo and Super Pump VS series:
    Hayward Max Flow VS
    Hayward Super Pump VS
    Pentair also has introduced a lower HP VS pump: Pentair Intelliflo i1
    The biggest risk on the electronic controls on VS pumps is the risk of electrical surges, as others have pointed out. In Florida, I would definitely look into a surge suppressor / circuit protector of some sort.
    If you are comfortable working inside your breaker box, adding a whole house surge suppressor is fairly easy.
    http://www.smarthome.com/48716/Intermat ... tor/p.aspx
    les_garten's Avatar
    May 2011
    PSL, FL
    153
    Thanx guys, I'm definitely going to read up on that surge protector. I had a Hayward pump on my last pool, thanx for the info on those.
