Thread: Closing IG Pool in N. Mississippi
    Hi all,
    I have a 16 x 32 IG vinyl pool with the aqua genie skimmer (no main drain), step returns, and 1hp sand filter. I am located in N. Mississippi, about 15 miles south of Memphis, TN. I was thinking because the winters aren't all that harsh, I maybe don't need to close the pool. Pool was just put in this spring, so this is my first winter. Just wondering if there was anyone from this region that could give me their opinion and/or experiences on whether to close or not to close.
    I was planning on simply buying a mesh cover just to keep the leaves out, and running the pump in recirculate mode whenever temps are expected to drop below 32. Is there anything else I would have to do, if I decide not to close/winterize.
    Thanks
    20,000 GAL, 16 X 32 IG Vinly Pool, Sand Filter, & 1.5 HP Hayward - Hot Spot Relay Hotub
    N. Mississippi.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,655
    Re: Closing IG Pool in N. Mississippi
    Must be in the Horn Lake area? You can keep your pool open if you like. Chemical uses drops way off the charts once the sun gets lower in the sky. LIke you said, just run your pump minimally daily, watch your levels, and run continuously in case of a freeze. Originally from Clarksdale here.
    Feb 2008
    Denton, TX
    5,061
    Do you have a freeze guard setting on your pump timer? If so, you can set that to turn on at about 35 degrees and it will cover you.
    Woodyp, that's the area I am in. Just a little bit south of Horn Lake.
    I think I will look into getting one of those timers.
    I got one last questions. If I don't close, should I run the filter only when temps drop, or is there some kind of minimum run time I should use through out the winter season, no matter the temp? I was thinking I would maybe run the pump in recirculation mode over night once a week, or every 2 weeks.
    N. Mississippi.
    Apr 2010
    East Texas
    9,655
    I run my pump 3 or 4 hours a day to help pile the leaves up for me. Then scoop them out.
