Thread: Auqa Logic by Goldline controls AQL-4 Model problem
    have the above control panel for my 16 x32 inground salt pool . After 5 years we are having problems with the control board. everything work almost except the timer section where you change the day and time . It is stuck in the sunday mode.. we had a power outage in the area when we went to check the pool it had control error. so we did the breakers for the panel and it work all except the timer.. can anyone help in this? Do not want to pay for a new board . Called the company and was told a tec had to come and check it out.. I don't need that charge ..
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: Auqa Logic by Goldline controls AQL-4 Model problem
    Welcome to TFP!
    I know this is an older post and no one answered it, but wanted to encourage you to continue to post and ask questions. Not every question gets an answer, but we should have at least welcomed you to the forum.
