Thread: Upgrading to iAqualink IQ900 with a IntelliPro VS-3050
    I must have searched for hours looking for information to help me with upgrading from the Aqualink RS PDA power control to the new iAqualink. The PDA PCB died and it was a lower cost option to upgrade to iAqualink than to replace. Unfortunately Zodiac doesn't publish publicly the installation manual for the new iAqualink. However the Aqualink RS One Touch install will get you close enough. The newer Zodiac boards come with 2 RS-485 4-pin connectors as opposed to one. All other connectors are the same though they moved to the bottom of the board. The communication cable from the new iAqualink box connects to one of the RS-485 terminals (I used the first one). IF you want to continue using your PDA for On/Off and Monitor functionality you will need to connect the comm cable from the PDA J-Box to the RS-485 terminal as well. You can wire both to the same one.
    Now here is the part that I struggled with: getting communication to work with my Sta-Rite IntelliPro VS-3050. The Jandy manual will tell you to wire through a the pump relay.... DO NOT WIRE to the pump relay. The pump should wired directly from the breaker. If you aren't confident in high voltage wiring use an electrician. StaRite and Pentair will tell you to buy an Intellicom II Adapter (a mere $150 "translator") but YOU DON'T NEED it. Page 18 of the Aqualink RS Install Manual, Section 3.3.4 details the pin and wiring configuration needed to connect the Pentair/StaRite control wire to the RS-485 Connector. I used the 2nd RS-485 termination block and connected the Yellow to Pin 2 and Green to Pin 3. With the Intelliflo pump powered on with the breaker you will need to reset the VFD by pushing all 4 Speed buttons simultaneously for 3 to 4 seconds and then power it off via the breaker. This reset step is what I failed to do and it took me hours to troubleshoot.
    Follow the iAqualink directions to get it connected to your wifi network. Power up the control board only and allow iAqualink to connect to wifi. All three LED's should be lit. Using the iAqualink Inerface, after you have set up you user account and added your pool, proceed to Menu>System Setup>VSP Setup. Click Pump/Model (#1) and select Intelliflo VS (the flo and pro are the same). If you have a VF I assume this same wiring configuration will work; the difference is you should select Intelliflo VF at this time. Click application and select Filtration. Click Speed Setup>Select your pump>Next - you can now program 8 DIFFERENT speeds with custom labels. You can program to your heart's content. The Jandy Manual for iAqualink is very useful in setting up your system.
    Once your system is programmed, power the Intellipro back on via the breaker. It should now operate via the iAqualink.
    Good luck,
    32k gal, 16x32 semi-IG, two speed cartidge filter, built 2002
    22,537
    Re: Upgrading to iAqualink IQ900 with a IntelliPro VS-3050
    Welcome to TFP.
    Thanks for posting that. It will undoubtly save someone a lot of trouble in the future.
    May 2014
    San Jose, CA
    7
    This is an outstanding post and saved me hours from troubleshooting a setup/integration process that is just not well documented or communicated by the suppliers.
    Thank you JSTEXASPOOL! I probably would not have attempted this without this post.
    For my situation, I had an existing iaqualink setup with an old single-speed 2HP pump (killing my elec bill) and wanted to upgrade to the Pentair Intelliflo VS pump (11018). Bottom line, I cut-out my old pump and wired it up exactly as described above and bingo!....worked as advertised. In my case, I didn't have to do the reset step (pushing all four buttons), my system picked up the addition of the vs pump and automatically took control through iaqualink (FYI - iaqualink disables your VS pump's on-board lcd/keypad panel while the pool is in auto mode). The most difficult step in the process was finding the Jandy red plastic connection block (6609 or 6609+) for the Pentair control cable, and to do this without spending $40-$60 for it (pool store special order price). I eventually got the right on ebay for $15.
    Thanks again.
    Apr 2017
    Vacaville, CA
    1
    Thank you for a great post. I am currently preparing for this change. I have already installed the aqualung upgrade. I am replacing my filter pump and my solar pump with one Pentair Intelliflo 2 VST. Just to confirm the control cable will power the pump off when the scheduled task is over (filtration for instance)? Also I have a 20,000 gallon pool and am wondering if you have a resource for pump speeds for filtration and then for solar. Any help would be appreciated.
    Jul 2017
    Wisconsin
    1
    Quote Originally Posted by Will Linne View Post
    Did you get this installed? I just upgraded my Jandy PDA-P4 to a iAqualink using the IQ20-RS. I am now looking at replacing the Jandy Pump with the Pentair Intellipro 2 VST. There is an instructable that shows to connect the wires like refferenced above but I can't seem to find any other references to setting it up like this.
    Mar 2017
    Monrovia, CA
    1
    Quote Originally Posted by jstexaspool View Post
    First, 4 years later and yes: this post is just money. Just had the IQ20 installed, and it turned out to be no more than an on/off switch. Couldn't access the VSP. Talked to Zodiac and they got the IQ20 up and going, but: still only an on/off switch. Realized it was wired incorrectly... So, I did the same (re-)wiring you mentioned above (Red-1; Yellow-2; Green-3; Black-4: Hey Zodiac: why not just publish that?)...and now IQ20 offline... But, went out to do the reset you described and: realized: the guy wired the pump to the relay. It won't reset.
    Anyway, it's dark outside and heading toward 38 tonight, and I can still run the VSP manually. Tomorrow! Stay tuned!!! And, thanks for the post from 4 years ago!!!
    33k gallons pebble surface (?), spa, slide, waterfall
    IQ20-RS (2017)/Jandy RS6 (2002!!! 6700 Rev C)/Jandy Power center
    Pentair Intelliflo VSP (4-speed)
    Hayward Spa Booster Pump/Hayward Booster Pump (Slide & Waterfall)
    Hayward Heater
