Thread: Adding Salt for feel not SWG how Much
    Jun 2008
    First off big thanks to everyone here for all the help.
    I am still preplexed by a low PSI reading but the detective work continues.
    Anywho I want to experiment with adding salt to my pool to get some of the benefits of salt water but not yet ready to go to the SWG side of life.
    So if a pool owner wanted to start down this path what should he do?
    What is the minimun amount, and should I build from here?
    How does this effect chemicals?
    55,000 In Ground Gunite
    Pentair CC Cartridge Filter 420 Sq Ft
    Polaris 360
    Skimlite Dually Pole and nets (highly recommend)
    No SWG-Yet
    No BBB-Yet
    ktdave's Avatar
    Katy, TX
    Re: Adding Salt for feel not SWG how Much
    It has little-to-no effect on other chems. Check out this thread:
    11,000 gal. gunite w/midnight blue and white pearl PebbleTec
    Intelliflo 4x160 pump
    Intellichlor IC-20 SWG
    Pentair cartridge filter 420 sq. ft.
    Mastertemp 400K BTU heater
    Legend Platinum cleaner
    Pool School
    JasonLion's Pool Calculator
    TF Test Kits
    You could add one bag of salt every few days till it gets to a level you like. Or you could get some test strips, measure the current level, and then add salt to 2000 ppm.
