Thread: aquarite board measures too high at leads
    I am having various issues with my Aquarite salt system.
    I changed the main board, then the flow sensor went out.
    I changed the flow sensor, and then board wouldnt work correctly.
    I had an old board, so I replaced the board to see if behaved the same, it did.
    So I put the new board back, and found something on the web that stated voltage across the two leads should be between 209 and 241, mine measures 253. When i put the new board back in, almost immedately two components burned.
    I am wondering this has to do with the voltage measured across the leads, and if so, what i can do to fix this.
    6000 ga, Summer Escapes 16' AG, Intex 1200gph sand filter
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: aquarite board measures too high at leads
    Welcome to TFP!
    I know this is an older post and no one answered it, but wanted to encourage you to continue to post and ask questions. Not every question gets an answer, but we should have at least welcomed you to the forum.
