Thread: Pump went dry overnight
    mariane's Avatar
    May 2012
    Southeast Michigan
    305
    Due to my carelessness, the water level went below the skimmer feed some time during the night. Now the pump whines at a high pitch. I disconnected the hose from the skimmer basket and put it directly into the pool water. It still pumps but still whines. I wasn't exactly ready to shut down for the season but this might be it. After reading other posts, am I right in thinking its time for a new pump?
    We have a 1 hp, 10 amp doughboy power pak pump, single speed and I run it 24/7. We've used it 7 years and got it from the neighbor when they moved, who used it 2-3 years. What kind of pump do others recommend?
    Thanks.
    16 x 28 Doughboy Mystic Garden AGP with 7' deep end (used expandable vinyl liner) ~11,800 gals. Deep end main drain. Thru-the-wall skimmer, one return at deep end. Media Master 150# sand filter. Doughboy PowerPak II pump, 1 hp. Pentair MinimaxCH 150m natural gas heater. Polaris 65 when it feels like working . TF-100 test kit. No longer 'pool stored' 6 years and counting. In sunny but fickle metro-Detroit.
    22,553
    Re: Pump went dry overnight
    For your size pool a 1 hp 2-speed aboveground pump would be a good choice.
    mariane's Avatar
    May 2012
    Southeast Michigan
    305
    Thanks Bama Rambler.
    Now all I have to do is keep the water circulating with a sump pump and chlorine until the temps come down and I can close down for the winter.
    Cherie's Avatar
    Jul 2008
    Wylie, Texas
    506
    http://www.poolsupplyworld.com/Pentair- ... 340206.htm
    Pentair Dynamo #340206. We have a 16x32 buried Doughboy with 7' deep end. We installed this pump four years ago and it's been running 24/7 (on low) since. It only gets turned off to backwash, which isn't very often since I use the skimmer socks. It's VERY quiet, even after four years of non-stop pumping.
    And our electric bill decreased significantly after we switched out the single-speed (which only ran 10-hrs/day) to the dual-speed (runs 24/7/365 on low).
    32x16 buried Doughboy, 4' shallow - 7' deep
    Pentair Dynamo 1 hp, 2-speed - Pentair 150# SD40 w/zeolite (75#)
    One skimmer/two returns/Aquabot Turbo T2
    mariane's Avatar
    May 2012
    Southeast Michigan
    305
    Thanks Cherie.
