Results 1 to 12 of 12
Thread: Updated test results and a question
    Here are my most recent test results. Finally got the TA down from 280 on 5/18. You all were right it is quite a process...
    FC 1
    CC 3
    TC 4
    pH 7.0
    TA 90
    CH 90
    CYA ~80
    Lots of chlorine to add tonite, but other that that how do things look. I want to add borates but have just been working on my PH/TA for the last month. Am I ready?? Also, we have a birthday party planned for Saturday. Could I get the borax & acid in tomorrow night and have the pool ready for this weekend, or should I wait? Thanks.
    fiberglass 13500 gal IG, cartridge filter, gas heater, 1.5 HP 2-speed pump
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Updated test results and a question
    With a CYA that high, you don't have enough free chlorine. Also, you have very high CC's. You need to shock, and soon. Use the CYA chart to see what your FC and Shock levels are, and if you want to swim by Saturday I'd get on that....
    Your ph is low. Congrats on lowering the TA, but now you need to raise the PH to about 7.4-7.6, which won't take much to do, and can be done by saturday. Don't retest the PH while shocking cause it will read inaccurately....
    ~Edit
    Oh I see now, you were going to shock anyway.
    Acid?
    I would raise your PH with arm and hammer washing soda or soda ash. Anytime is fine.
    Do you have an SWG? 80 for CYA is a bit high, unless you have a SWG.
    Guest
    Quote Originally Posted by derek1027
    FC 1
    CC 3
    You need to shock to get rid of the CC.
    TC 4
    pH 7.0
    Keep aerating to bring this up to about 7.5 Don't use soda ash, it will raise the TA!
    TA 90
    CH 90
    This is a bit low for fiberglass, shoot for around 250 ppm
    CYA ~80
    If you have a SWG this is perfect. If you are using bleach this is still a bit high but workable.
    Finish getting the rest of your numbers in line and then add the borates.
    You guys are so quick!!! 2 replies before I even made it back from The Pool Calculator. Thanks again!
    11,969
    Waterbear, I'm curious...if he aerates to raise the PH to 7.5, how much will that lower the TA do you think?
    I'm still learnin', still learnin'. That's what I love about this forum....
    Also, how much would soda ash raise the TA? 90 is good, actually lower than mine, come to think of it....
    Guest
    Quote Originally Posted by frustratedpoolmom
    Aeration will raise the pH without raising the TA. Adding acid to drop pH lowers TA. That is why you aerate after adding the acid.
    Borax will raise pH and only slightly raise TA.
    Soda ash will cause both pH and TA to rise and will make TA rise faster than baking soda.
    so if he aerates his TA will stay at 90 ppm which is really the high end of where it should be for unstabliized chlorine such as bleach.
    11,969
    Gotcha.
    Thanks again for your expertise, as always!!!
    Sep 2007
    Georgia
    30
    Where should TA be for a pool using BBB method. I have 18 X 36' inground vinyl liner. I am in the process of lowering my TA which was 130 so that I can add borates to pool. What should be my target for TA?
    16 x 32 IG Vinyl
    Sand Filter
    It depends on your chlorine source and the amount of aeration your pool gets. With no special sources of aeration and bleach try TA between 70 and 90. For a SWG then 60 to 80. For trichlor tablets 100 to 120. For extreme aeration then 50 to 70.
    Sep 2007
    Georgia
    30
    Thanks, I will continue to add acid and aerate until I get my TA down some. It is at 120 right now.
    16 x 32 IG Vinyl
    Sand Filter
    May 2008
    Pensacola Florida
    8
    First several weeks ago I had a real problem with algae blooms on the bottom of the pool ... you guys helped out and my pool has never been better.
    My numbers though now I'm a bit concerened with what do I do if anything
    This morning:
    30,000gal vinyliner double skimmer
    fc 2.5
    cc 1.5
    tc 4
    ph 7.8
    ta 110
    cya 40
    ch 80
    water temp 86
    Questions?
    1. Why all of a sudden is my combined chlorine high (1.5) ...or is that not really high
    2. Is my TA a bit high?
    3. P.h is a bit high yes?
    4. what is optimal range for my florida pool?
    Smile you might make a difference
    Dan
    Guest
    Quote Originally Posted by dannybye
    Questions?
    Don't know if you been getting the rains on the west coast that we've been getting in St. Augustine but if you are that could explain the high CC. Shock the pool to get rid of it. Probably algae trying to get started. Also, you are keeping your FC a bit low if you normally keep it at 2.5. I would not let it go below 3 ppm. Shoot to maintain about 4 ppm and you should have no problems.
    If you drop it to around 70-90 your pH will not rise quite as fast.
    It's the upper limit of acceptable, you don't want it higher. What I personally recomend to my customers is to lower it to 7.5-7.6 when it hits 7.8 and to try and keep it in this range.
    Your numbers look good. The only thing you might want to do if you are getting a chlorine loss from sunlight is to raise your CYA slightly but try my other suggestions first and see how it goes.
