Results 1 to 11 of 11
Thread: New Gunite Pool. Main drain clog
    Hi all,
    New the the board here. I have a new Gunite Pool with River Rok. My main drain is clogged...most likely in the T between the 2 drains. I'm sure its with the RIver Rok plaster from the installation. My PB came out with a diver today with a failed attempt to push water in both directions to unclog it. This did very little to help. Only a small amount of water will come through when I close my skimmers and will quickly starve my pump. My PB now says its fine and that the pool is not meant to only have main drains open without a skimmer. Any ideas on how I can fix this situation?
    gtemkin's Avatar
    Jun 2008
    Seattle, WA
    738
    Re: New Gunite Pool. Main drain clog
    One way to fix it is to not make a final payment to the PB. That will get his attention.
    21K gal 16' x 40' in-ground pool built 1959, old school with Jacuzzi bronze pump, American Products 24" Sand Filter & Americana Multiport valve, Jandy Lite2 millivolt heater, Coverstar cover, and classic Kreepy Krauly.
    Ha. Thanks. The amount i owe him is nothing compared the horror of this pool. Will post pics of how bad the river rok looks next....
    Feb 2011
    Petaluma, Ca
    665
    Quote Originally Posted by sudolg
    Hi all,
    I don't know the fix but this statement is lame, never heard that before, you should be able to have all suction through the main drain if you choose.
    DONE, 20 x 40, inground gunite, 30" raised bond beam with 3 12" sheer descents, 8' diving board, pentair 420 cartridge filter, vs-3050 pump, intellechlor ic-40, auto cvr, Tahoe blue pebble tech, 6ea 4' x 12.5' & 2ea 1' x 12.5' helicol solar panels, legend robotic cleaner.
    May 2013
    North East Ohio
    959
    Quote Originally Posted by bobby1017
    Hi all,
    I agree...have a new pool and I can run FULL BORE off the main drains and get full suction. Something is WRONG for sure with your setup.
    14,750 GAL IG Fiberglass (16 x 33) NE Ohio || Jandy 1HP 2 speed Pump || Waterco MultiCyclone 16 Centrifugal pre-filter (removed due to not working with sand filter) || 30" 575 Lb. Sand Filter || AquaCal 140K BTU Heat Pump || Solar Cover || Inter-fab Adrenaline Slide || GLI Monsoon Solar Cover Reel || K-2006C Test Kit || BBB with Liquid Chlorine Stenner Injection || Rayner Mighty Mesh Winter Cover
    Thanks. I know this is the case but just wanted to ensure I wasn't missing something. Again, I'm getting just a tiny bit of flow now so they did something but still clogged. They are now talking about poring some acid down the main drain pipe to see if they can loosen the stuff. Hoping pure muriatic acid doesn't eat throughthe glue on the PVC lines....
    May 2013
    North East Ohio
    959
    Any way you can run a snake through the lines ? They have those "water snakes" that might help.
    gtemkin's Avatar
    Jun 2008
    Seattle, WA
    738
    I'm not familiar with River Rok but if the clog is composed of a cement binder material and if it's at the lowest portion of the drain piping system, would it be possible to break up/weaken the clog by pouring full strength muriatic acid into the drain. From what I can see online, PVC piping appears to have satisfactory compatibility with muriatic acid. Not sure if glued joints are just as compatible and the job would likely require a full drain of the pool - which is made somewhat harder without a main drain!
    I've got no experience doing this and it's kinda hair brained, but with care it might work.
    Edit: ...and before doing anything, it seems like it would be a good idea to get the pipe video scoped to verify the actual cause.
    Yeah, i agree with you. I think this is the best approach. Draining pool would be best. I do want to get it scoped to see the clog for myself and exactly where it is just to be sure. Thanks for the comments....
    With regard to the snake....not sure....I'm sure its plaster because this pool is brandy new so may be hard to move without chemicals. Perhaps scope first and go from there.....
    Apr 2013
    Sacramento, CA
    2,769
    You don't say where you are. Do you have building inspectors? The PB cannot walk away without insuring that you have dual drains that are hydrostaticly balanced. Otherwise he must close off both drains. In other words both drains must flow equally into the pipe beyond the T. Any clogs that might affect this are very problematic.
    This is not just that he has not completed your pool to the contract specifications, its a life safety issue.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    What a lousy excuse from the PB. Wishing you the best of luck on the drain. What's wrong with the finish, and what has he said about that?
    Essential Links:
