Thread: small pebbletec holes
    Hi i put my driving mask on yesterday and noticed that i have about 30 smaller than a dime sized areas where the pebbles are gone and i can see white plaster under where the pebbles are gone. Can this be repaired? how quickly should i get on this? we are having a very hot summer here in southern California and don't want to drain the pool for repairs in this 100+ heat
    Also does anyone know a good pool repair place in the temecula or murrieta, ca area?
    thanks
    17,000 gal pebble tech in ground pool no spa, southern ca.- cartridge filters- 1 hp pump single speed, solar heated, 10 years old.
    Jul 2012
    CA
    240
    Re: small pebbletec holes
    Sorry I don't know of any in socal. Is your ph low? the water becomes corrosive and might loosen the finish.
    25k I/G ecostar ccplus Polaris plaster
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    I don't know what caused it, but it will probably be fine until you can get it fixed in the off season.
    Essential Links:
