Thread: Can't see all the posts
    Mar 2007
    Morris, IL
    477
    Seems like an odd thing. When I go to check the new posts, I can only get the most recent ones, usually like the last two or so. If I go directly through the main page to the thread, even with 4 pages, no matter what I get the last page with the last couple of posts. If I open the thread it should go to the page 1, but it doesn't, if I open page 1 it has no effect. Page two takes me to the same place. This is only an issue since the new search for new post thing has been implemented. Any ideas?
    steve
    Above Ground / 18' Round / Vinyl Liner / Sand Filter / 100K Gas Heater / Salt Added / No Nature2
    Mar 2007
    Morris, IL
    477
    Re: Can't see all the posts
    Well, since nobody took this on, I found the reason. All I needed was to have the time to mess with it. In my profile I had the boxes for display posts within the last 1 day checked for some reason. I sort of remember doing it, and if I did I imagine that it was thinking that it would be for displaying new posts. The thing is, I could not see any posts AT ALL made previously no matter what.
    steve
    Glad you were able to find the problem!
    8200 gallon 20' x 48" round vinyl frame pool,
    Intex SWCG, 12" sand filter, 1600gph pump, TF100 test kit
    SeanB's Avatar
    Mar 2007
    Missouri City (suburb of Houston, TX)
    2,622
    Sorry, I'm the one who would have need to go into your profile and change your settings. I may have been a little busy when this post came across. Glad you remembered to undo what you had done. ;) lol
    TFP Founder
    My Pool: 13K gal IG gunite with 7' spa, Pentair Cartridge Filter, Intellichlor IC40 SWG, Polaris 280 Cleaner, TF-100 Test Kit w/ salt test.
    Mar 2007
    Morris, IL
    477
    All is good. I figured it was something that I could change. All I was looking for was a solution. I knew I could get it with time, but I was busy too. Hope the site is going to be more stable this time. Like all you need on top of normal life is more problems. Thanks
    steve
    SeanB's Avatar
    Mar 2007
    2,622
    Yeah, until we started maxing our the shared server, things were rock solid for over a year.
    I'm just looking forward to working out the remaining bugs on this new server / software so we can get back to pool care.
    TFP Founder
