Thread: Pool closing question
    Jun 2013
    Northern NJ
    123
    Hi I am scheduled to have my pool closed next week. If I test the water and find that my chlorine is low should I add more. I don't expect anyone to be using the pool till closing. Also ph and alkalinity
    Thanks
    36,000 gal IG vinyl. Haywood pump and heater Hayward DE filter blue diamond robot. Hayward Aqua Rite SWG AQR-15
    22,548
    Re: Pool closing question
    Absolutely add more if it needs it.
    Jun 2013
    Northern NJ
    123
    Even if the pool will not be used for swimming?
    22,548
    Unless you want it turning green on you. Do you normally chlorinate it even if you're not going to swim in it or do you only chlorinate it when you're swimming?
    Jun 2013
    Northern NJ
    123
    Point taken thanks
    38,279
    Is you water temp below 60 degrees already as suggested in Pool School for closing?
