Thread: No Suction on pump
    Masspools's Avatar
    Jan 2013
    Cambridge Massachusetts
    35
    No Suction on pump
    Hi all
    Pentair whisperflo pump 1.5hp 3ph.
    New pump installed in commercial facility, trying to prime it and it won't suck in the water. I have no back flow restrictions since the filter valve is on waste. All valves open on the suction side, the pump has suction, I checked the impeller. When I turn off the pump the water flows into the pump from the suction line on front. What could be happening here?
    Thanks
    James
    Jul 2010
    Philly
    332
    Re: No Suction on pump
    With 3 phase it's an easy mistake to wire it where the rotation is backwards.
    Bill
    18'X4' 7600 Gal AG
    3/4 HP Pentair Pump
    Hayward S166T 100 lb sand filter
    kellyetheredge's Avatar
    Mar 2013
    Lubbock, texas
    43
    3 phase motors: at the breaker/disconnect swap any of the three wires. Swap 1 and 2, 2 and 3, 3 and 1.......just swap any two to reverse direction in any 3 phase motor. You can also swap any two wires in the "****** head"; the junction box mounted on the motor.
    14,364gal AGP
    Intex Ultra Frame 16'x32'x52"
    Krystal Clear™ Sand Filter Pump & Saltwater System - 2,650 GPH**Nite-Brite Halogen Pool Light
    TF-100 Test Kit (This kit Rocks)
