Thread: Salt Vs Chlorine
    Salt Vs Chlorine
    First of all I appreciate everyone's insight! We are in the final stages of designing our pool. I know this topic has been discussed at length all over the Internet, but can I get everyone's take on salt vs chlorine for a first time pool owner? I don't mind doing all of the work, just want to know about corrosion of equipment and decking/moss rock.
    Thanks
    27100 gallon in ground Pool/Spa, SWG, Pebble Sheen-Aqua Blue, (All Pentair Equipment) Pentair VS Pump, Cartridge- filter, build completed Dec. 2013, Houston, Texas
    38,343
    Re: Salt Vs Chlorine
    Welcome to TFP!!!
    A "salt" pool IS a chlorine pool. The SWG will just "generate" the chlorine (FC) for you from the salt in the water. Alternatively you have to add the FC (daily using liquid chlorine / bleach) or you can get a system to automatically add the bleach for you (liquidator or a peristaltic pump).
    There is really very little to worry about in regards to equipment corrosion, but if you have soft rock (I am not sure what moss rock is), then the salt can result in erosion, although this is usually more of a concern where there is little rain to wash the salt off the rock and it can build up.
    Thanks. If I seal the flagstone and deck annually, will I be ok. We live in Houston. I have a million questions! And what is the life span of the Salt water equipment?
    Again thanks
    38,343
    Flagstone ... Texas ....... seems like most of the reports of problems come your area or AZ.
    Is the flagstone all around the pool? ... if so, I would skip the SWG and start looking at the other options.
    BTW, the SWG cells generally last 3-5 years. The controllers should last a lot longer than that.
