Thread: TA and PH levels
    Aug 2013
    dallas,tx
    79
    TA and PH levels
    tests today
    FC 9
    CC0
    PH 7.4
    TA 100
    CH 300
    CYA 135
    After slamming one week ago, the FC finally dropped below 10 to test the PH. I am still in the learning phase, and curious about the PH and TA effects on the water. I have a water fall on the spa and another waterfall on the pool. I see that aeration will raise the PH. The current reading for TA is 100 and to reduce to 80 to 90 I need to drop PH and aerate. Is my TA too high or should leave alone and retest in a few days? I will raise the FC back to 11 but wanted correct any PH or TA problems first. BTW, I am working to reduce CYA. Did partial drain before slam and reduced from 360. Will do again as water restrictions ease. Also does Polyquat 60 impact PH or TA. I am using while CYA is high
    2009 19k, IG, Quartzscape negative edge w/waterfall, 8' raised spa w/waterfall ,Pentair WF28 2hp, Jandy 1.5hp pump for water fall feature, Polaris 280 cleaner with booster pump,400,000 Jandy LXI heater, Jandy DE 60 filter.
    Aug 2010
    Dallas, TX
    4,052
    Re: TA and PH levels
    If your pH stays steady enough for you, don't worry about the TA. If it keeps going up more than you like, drop pH to 7.2 and keep doing so until you get TA to 70-80.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,052
    As it says in Pool School on how to lower TA: There are two reasons to lower your total alkalinity (TA) right away, because you want to slow down the rate that the PH rises, or if high TA is contributing to a high calcium saturation index (CSI) which puts you at risk of calcium scaling. You shouldn't lower TA just to reach a target number. Make sure you actually have one of the above issues before lowering your TA.
    Polyquat shouldn't affect things.
    Assuming the water is clear, stop fussing and go swimming.
    Aug 2013
    dallas,tx
    79
    Okay. Yes water is very clear
    This past weekend when we were swimming I had complaints of itchy skin and burning eyes. My FC was 15 then, so I don't know what the PH was. I have not added anything since that time and was just able to test the PH today at 7.4. I assume with my water falls running each day this will come up. Would the slam process have lowered my ph and aeration now bringing it back up? Just trying to understand what is causing itchy skin and burning. Have not had that issue before starting the change to bleach.
    Smykowski's Avatar
    Sep 2011
    3,065
    Quote Originally Posted by dkbrat
    It's likely the volume of bathers. Did anyone come to your house, slather on the sunscreen, and immediately jump into the pool? Between that, and any sweat, spit, or pee (yeah, it happens) you probably had an acutely high level of CCs doing the damage.
    The only way to prevent/minimize the effects is to ask your guests to wait 20 min after putting on sunscreen before swimming, don't pee in the pool, keep the pumps running while everyone is swimming, and keep the FC a little higher than normal during the party.
