Thread: Maximum Chlorine levels to swim?
    Hello,
    will be starting to treat a mustard algae problem once my new test kit comes in. What is the highest ppm of chlorine that you can swim in? According to the chart, I will have to hold and maintain 37 ppm to treat my problem based on 67 ppm CYA. I find it easier to brush the pool from the inside, rather than outside. Thanks for any input!!
    24' AGP, vinyl liner,Sand filter with DE enhancement, single speed Hayward pump, Hayward 150kbtu heater
    BBB method convert from FROG system
    TF100 test kit
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,643
    Re: Maximum Chlorine levels to swim?
    Safe to swim up to NORMAL slam value for your cya level. Not mustard slam values.
    38,470
    Welcome to TFP!!!
    Have you read the article in Pool School about Mustard Algae? Are you sure you have it? Many people come here thinking they have some special algae, when in fact it is just like everyone else's:
    pool-school/mustard_algae
    Note that you only raise up to Mustard SLAM level ... AFTER ... you have competed the normal SLAM Process.
    As Woody said, it is safe to swim up to normal SLAM level ... although if you are just in the pool briefly to brush, that should be fine above that level ... just wear an old suit
