Thread: Not covering pool this winter
    New pool, dont want to cover it because covers are a pain..We do get snow and ice here in Oklahoma, Whats your "closing procedure" as far as the pump, filter, skimmer etc
    Oklahoma
    30X20 Gunite pool completed in July 2013
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,572
    Re: Not covering pool this winter
    I just keep mine clean, don't cover, run the pump minimally each day on a timer, and run it continuously if we have a freeze.
    hmmmm so what if theres a blizzard? I would have to let it freeze...pipes be ok?
    Oklahoma
    peterdaly's Avatar
    Aug 2013
    Fayetteville, NY
    188
    Frozen water in your pipes will break your plumbing, if not properly winterized.
    Never done it myself yet, but I understand the winterization
    process for places that go below freezing on a regular basis, is to get all water out of the plumbing, capping the jets, and adding environmentally safe antifreeze in key places.
    For short periods of freezing, constant running of the pump can prevent water freezing and keep pipes safe. Many automatic controllers have a built in function to do this, called freeze protection. If you get serious winter weather, freeze protection like this is probably not enough.
    Fayetteville, NY -17K gal, IG vinyl, Hayward SP2300VSP Max-Flo Variable Speed Pump, FlowVis Flow Meter, Sand filter
    Self designed Arduino powered automation for pump and solar control, Solar Attic Pool Heater, AutoPilot Digital SWG, TF100
    ship of fools's Avatar
    Nov 2011
    Albany, NY
    495
    Will it freeze solid or for an extended period of time??
    If so you need to winterize .... just do a search on here and you will find detailed instructions.
    It isn't all that hard to do and it is significantly easier than repairing ruptured pipe.
    21,000 gallon inground
    Haywood Sand Filter
    Vinyl Liner
