Results 1 to 7 of 7
Thread: Ph unstable
    Ph unstable
    Let me first say, I am new to pool ownership. We have owned our house since June that had a pool built in 2008. Since living here, the pool has been crystal clear and all I have done is added salt (based on salt cell reading which I have now figured out is incorrect and I added too much salt). About a month ago, I started noticing white flakes which I now know is calcium. Our tap water is high in calcium, so when I top it off, it won't lower the calcium . I took my water in to have it tested and here were the results :
    FC 4
    TC 4
    Salt 4,500
    CYA 20
    TA 80
    pH 8.0
    Phosphates 500
    CH 650
    I used Alkalinity up to increase the TA before adding acid. I then added 32 ounces of MA. I then added water conditioner to increase the CYA.
    My numbers as of today are:
    TA 120
    pH 8.2
    CYA 60
    Since having the water tested a week ago, I have added a GALLON of MA and I still can't get the pH to stay in the range. Yesterday, it was 7.4 and today 8.2?? I am so frustrated!! Ant idea why I can't get the pH to stay in range?
    10,000 gallon inground saltwater pool painted bottom
    Aqua rite goldline generator
    Hayward T-Cell-15
    Hayward swimclear cartridge filter
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: Ph unstable
    Welcome to TFP!
    The pH is rising because the TA is too high and you are using a saltwater chlorine generator. You should have been adding acid to keep the pH in check. Not testing and maintaining the pool for years was risky.
    The flakes are calcium carbonate being formed in the saltwater chlorine generator cell because your water is out of balance and over-saturated with calcium carbonate. Assuming 85F water temperature, the Calcite Saturation Index you can calculate in The Pool Calculator was (before you added Alkalinity Up) +0.56 and now after adding the Alkalinity Up it is +0.89. This assumes the pool store tests are accurate, which is doubtful. Adding Alkalinity Up was the wrong thing to do -- your TA was fine where it was and could even have been lowered more given the tendency of the pH to rise and the already high CH.
    Start reading the Pool School. In particular, you want to look at Water Balance for SWGs and how to Lower Total Alkalinity.
    Re: Ph unstable
    I have only owned the pool for 3 months, it was built by the previous owner. So it wasn't neglected for that long. And I actually had a pool guy initially that had been adding acid, but I fired him and am now on my own. I assumed the pool store knew what they were talking about, but clearly they were just trying to sell products!!
    So at this point, I just need to continue to add acid to bring both the TA and pH down?
    Hayward T-Cell-15
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: Ph unstable
    That's correct...just keep adding acid to bring the pH into the acceptable range, and the TA will gradually come down along with it.
    Re: Ph unstable
    I had it in acceptable range yesterday...7.4. How does ut jump so much overnight? Could this indicate a bigger problem? I am going to start going through the pool school tonight.
    Hayward T-Cell-15
    30,421
    Re: Ph unstable
    It doesn't. You have a testing error somewhere. I wouldn't bother trying to reconstruct what happened but go forward and see if your tests don't even out.
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: Ph unstable
    See Test Kits Compared in the Pool School and get one of these recommended test kits (the TF-100 is the better value).
