Thread: Plug holes in Ultra Frame for winter?
    I'm planning on winterizing my 18' Ultra Frame this year and leaving it up in NY. I'm going to disconnect the valves and hoses. Do I need to do anything with the holes left in the liner from the valves? Or can I just drain the water below there and leave them open so any extra water will just flow out?
    Intex Ultra Frame 18'x48"
    Intex 14-Inch Krystal Clear Sand Filter Pump
    Intex Intex Krystal Clear Salt System (not yet installed)
    Re: Plug holes in Ultra Frame for winter?
    While I am pretty sure leaving the holes empty is fine, I too would like to know the opinion of others.
    Intex 18'x48" Ultra Frame
    2 - Intex 1500gph Type A cartridge filter pumps
    One thru-wall skimmer.
    Manual care monitored with the TF100 Kit
    Jun 2013
    Manitoba, Canada
    153
    I would think to leave them open so that if you have heavy rain or snow fall, the excess will still drain away and keep your level where it should be for the winter.
