Results 1 to 9 of 9
Thread: Intex sand filter size
    Sep 2013
    Gardiner, MT
    16
    We have a 15 ft by 36 inch Intex metal frame pool and want to upgrade the filter to a sand filter and separate salt water system (thanks for the insight on not buying it together) but I am having a hard time figuring out what size sand filter I need...1200 gph, 1600 gph, 2650gph. They are all similar in price on Amazon but I don't want something too big or too small that it doesn't work correctly or won't allow vacuuming (which I hope to purchase, as well).
    Thanks for your help!
    Intex Ultra Frame 14' X 42" AG, 4000 GAL, Intex 56671EG 2,650-Gallon Sand Filter Pump and Intex 54605EG Krystal Clear Saltwater System
    22,553
    Re: Intex sand filter size
    Get the 2650 without hesitation. No question, the best deal.
    Sep 2013
    Gardiner, MT
    16
    One more intex filter/saltwater question
    If we get the 2,650 gallon sand filter (http://www.amazon.com/gp/product/B002V1 ... PDKIKX0DER) for our 15ft by 36 inch Intex pool, is this the right salt water system? http://www.amazon.com/gp/product/B00AA8 ... PDKIKX0DER
    Thanks!
    22,553
    Yes, that's the one. Both of those units will make a good setup.
    Sep 2013
    Gardiner, MT
    16
    thank you!
    Sep 2013
    Gardiner, MT
    16
    I am sorry, one more question. I see that there are salt water test kits and I know there are regular test kits. Do I need both? Do you have one you might recommend? Sorry we got the pool for free from a friend (although we will probably need to purchase a new pool next year (now that we know how fun it is!) because this one has holes in the bottom we have had to patch...lots of holes...like 8 holes). We don't have a test kit or a vacuum, yet. I know we NEED a test kit! I feel like we need a vacuum to get the "stuff" off the bottom of the pool. Thanks for your help!
    Just trying to figure this all out. Will continue reading through all the info on this site, as well. It is great! My husband is concerned about the water getting "slimy" and not being correctly balanced so just trying to get stuff ordered quickly before the pool gets bad on us (I don't know if that can happen quickly). Will go do my homework now!
    Aug 2010
    Dallas, TX
    4,052
    I would say you can probably get away with not having the salt kit if you can estimate how much salt you need to add, and if your SWG tells you if salt is low. The AquaChek strips to check salt aren't too expensive if you just want something to manually test with. The silver nitrate drop test has been far more consistent for me, but I only needed it when calibrating my SWG (you probably will NOT need to calibrate yours).
    DigbyAllen's Avatar
    Westchester, NY
    113
    +1 for the 2650. Best thing I ever bought for my pool.
    Jim
    Intex 15' x 42" -- 4,000 gallons
    installed August 2012
    Intex 2650 sand filter, Hayward skimmer
    TF-100 test kit, TFP method
    38,475
    Look here for the Recommended Test Kits ... these do not have the salt test, but that can be added separately if so desired.
