Page 1 of 2 12 LastLast
Results 1 to 20 of 22
Thread: Salt Level Test
    Salt Level Test
    What would you reccomend that I purchase to test the salt level in my pool? I have a panel that displays my salt level, but I think it is underestimating my salt level. It is reading 2700 but I think it is higher.
    Thanks for your help!
    East TN
    13,000 gal San Juan Fiberglass Pool;SWG; GoldLine Pro Logic Controls
    Hayward Sand Filter; Hayward Max-Flo XL Pump;Polaris 380; Hayward ColorLogic LED
    Raypak Gas Heater
    Aug 2010
    Dallas, TX
    4,052
    Re: Salt Level Test
    I have had the best luck with this test:
    http://tftestkits.net/R-0718-Silver-Nit ... t-p76.html
    He has AquaChek strips that are cheaper, but I find the silver nitrate test to be consistent.
    Re: Salt Level Test
    Is the liquid test more accurate than one of the electronic salt sticks that they use at the pool stores to check salt? Thanks
    East TN
    Raypak Gas Heater
    ComputerGuyInNOLA's Avatar
    Oct 2012
    Mandeville, Louisiana
    604
    Re: Salt Level Test
    I use the Taylor K-1766. I calibrate my SWCG to it.
    Gunite/Plaster pool at 13k gallons. All Jandy with CL340 series cartridge filter, 1.5 HP Jandy Stealth pump. Jandy 1400 SWCG and PDA4 controller. Dual waterfalls. Polaris 280. Pool installed August 2012. Southern Louisiana. And lets not forget my trusty TF100 test kit!
    Aug 2010
    Dallas, TX
    4,052
    Re: Salt Level Test
    As far as I know, it gets no better. I only have experience with these though, I have no experience with electronic systems. I can't imagine how those would be more accurate than a drop-based, precipitate, quantitative test set though.
    MikeInTN's Avatar
    Middle Tennessee
    1,335
    Re: Salt Level Test
    Quote Originally Posted by ComputerGuyInNOLA
    + 1. Same here.
    sent from my Samsung
    24' x 52" AGP - approx 13,500 gallons
    Pentair Optiflo 1 hp/2sp pump w/ Swimpro Voyager 150 sq ft cartridge filter
    Intex 8110 SWCG
    "Fear the Schnauz!"
    Seanhan's Avatar
    Mar 2013
    Fort Worth Texas
    300
    Re: Salt Level Test
    I use a salt tester i got on ebay for 30 bucks
    Its quite acurite so far.
    Sean Hannon
    30,000 Gallons gunite pool Coated by Fibertech
    Hayward Pro Grid 72 / Hayward multiport
    Circupool V3 VS pump
    CirCupool SWG RJ 60, 400.000 btu raypak , Built in SPA
    Re: Salt Level Test
    Thanks!! I ordered the K-1766. Now, how do I callibrate my SWCG once I get a true reading? I attached a pic of my control panel:
    East TN
    Raypak Gas Heater
    38,275
    Re: Salt Level Test
    As far as I know, you can not recalibrate the Hayward SWG. You can temporarily override the average salt reading with an instant salt reading, but it will drift back to the previous average.
    Re: Salt Level Test
    Thanks for the help! I recieved the R-0718. How do I do the salt test. How much water? How many drops? etc...
    Thanks!!
    East TN
    Raypak Gas Heater
    38,275
    Re: Salt Level Test
    It tells you how on the sheet inside the test box.
    I think it is 10ml water, 1 drop or the yellow, then count drops of the other until it turns a brick red times 250ppm ... {from memory}
    Or 25ml water and each drop is 100ppm.
    Re: Salt Level Test
    I didn't get a test box, I just ordered the R-0718 seperately. Was I suppose to order anything else to run the salt-level test? Do I need a special kit?
    Thanks!
    East TN
    Raypak Gas Heater
    38,275
    Re: Salt Level Test
    Re: Salt Level Test
    Thanks! I just ordered the kit.
    East TN
    Raypak Gas Heater
    Re: Salt Level Test
    I received my salt test kit today. It showed my salt level at 4200. My display is showing 2600. Is there anything I need to do? I am not having any problems with my chlorine levels. I am afraid my display will keep dropping and cause it to go to low salt level even though the level is high. If Temperature makes a difference, my water temp is 92 degrees.
    East TN
    Raypak Gas Heater
    38,275
    Re: Salt Level Test
    How old is the cell? Is it dirty? This is a sign of a dirty cell or one near the end of its life.
    Re: Salt Level Test
    The cell is clean. We just checked it last week. It is 4 years old. We never close the pool so it runs year round. Right now I have it at 20% and it is maintaining the chlorine level.
    Thanks!
    East TN
    Raypak Gas Heater
    38,275
    Re: Salt Level Test
    3 to 5 years is kind of the expected life time ... and yours runs year round.
    If you replace the cell, you may find you have to replace water to lower the salt level.
    Have you had the cell tested at a pool store?
    Re: Salt Level Test
    I have not taken the cell to the pool store. I guess I should do that. If I observe the test at the pool store will it be obvious to me the cell is bad or could they tell me it is bad when it is still good? If it is stil making chlorine at such a low percentage should I still have it tested?
    Thanks!
    East TN
    Raypak Gas Heater
  20. Back To Top    #20
    38,275
    Re: Salt Level Test
    I am not sure how obvious the cell test is. I do not know if it is a go/no go where it produces or not ... or if they can tell if it is just degraded. i would guess then have water in the correct salt range and see if it will produce ... if your cell is giving low salt readings, then it will not work.
    The work around is raising the salt in your pool so the unit keeps producing. The downside is when you replace the cell, your salt level will be too high.
    Have the pool store test your salt level as well to confirm you reading.
