Thread: "Plugged" Filter-Elements 4-run WITHOUT D.E. installed : ?
    MAD JAX's Avatar
    Sep 2013
    "At Large" ; )
    2
    I ran-short of D.E. the last time I back-flushed awhile ago and just got some in yesterday...meanwhile My Filter Elements seem to have become perpetually plugged-up, for despite My repeated "Back-Flushing" I can't get My system pressure to stay "Normal" for very-long at all...I've read of this situation before - where the D.E. Filter Elements PLUGGED-UP for running the System WITHOUT any D.E. installed ~ but can't remember how they may become cleaned-up to then be "re-started" WITH D.E. properly installed : ?
    "Impossible" is a degree of difficulty ~ set by imagination for lack of motivation
    22,551
    Re: "Plugged" Filter-Elements 4-run WITHOUT D.E. installed :
    Welcome to TFP.
    Have you broken down the filter and manually cleaned the grids? That's where I'd start.
    MAD JAX's Avatar
    Sep 2013
    "At Large" ; )
    2
    I'm looking to get a container (30 gal. Plastic Garbage Can, etc.) large enough to contain them for a good soaking in either a Muriatic Acid or Bleach solution for the next-time I take it completely apart...
    I've back-flushed it (incl. "Rinse") again and immediatly added D.E., and NOW it seems to be working great ~ the Water is crystal-clear and the Vessel Pressure is holding-steady @ 22 psi ~ go-figure : ?
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Welcome to the forum Jax.
    Just keep an eye on the pressure to see what it does.
    Essential Links:
