Thread: Intermatic T40004RT3 Timing Control Center
    Jul 2013
    Puerto Rico
    76
    Hi!
    I have an Intermatic T40004RT3 Timing Control Center. The unit has a Transformer built in for the low voltage lights, but the wiring from the breakers comes into the transformer and then goes out to an external Safety Volt ST-100 unit and then on to the lights.
    Is this a normal setup?
    Why 2 Transformers? Maybe redundancy?
    I'm installing an Aqua Plus from Hayward and need to know if the Transformer inside the Intermatic is required.
    Please help!
    Thanks!
    JGV
    Pool: 6,500gal Plaster (Pool & Spa), Capsule Shape, 25ft x 8ft, 3ft to 5ft depth
    Spa: 6ft diameter, 3ft deep
    Equipment: Hayward DE3620 Filter, EcoStar VS Pump, Aqua Plus Controls & SWG
    Jul 2013
    Puerto Rico
    76
    Re: Intermatic T40004RT3 Timing Control Center
    The answer:
    The Transformer inside the Intermatic Unit is a 300w Transformer for the Main Pool Light and the Smaller Safety Volt Transformer is for the Spa Light (100w)
    J
