Thread: Connecting Light to Easy Touch 4
    Jun 2012
    Phoenix, AZ
    17
    I am connecting a new LED light to a newly installed ET4. I want to clean up the original pool light junction box/switch/outlet setup and instead plumb directly to the ET with a short 1/2" pipe extension from the copper pool light conduit. I will install the new outlet in the ET knockout. Both the light and outlet will have their own dedicated gfi breaker. Do I have to keep the old pool light junction box? Or can I do what I want to do, get rid of the clutter and wire the light cord directly in the panel?
    Also, I would like to use copper pipe for the extension but is galvanized okay if thick wall copper is hard to find?
    I'l try to post pictures so you can get see what I am doing.
    13000 gal, IG, 21 year original plaster pool, 1.5 HP Pentair, 60 sqft DE Pentair FNS plus, Pool cleaner Me (Dolphin Dynamic motor kaput).
    Re: Connecting Light to Easy Touch 4
    Pool lights are required to have their cables terminate in a listed pool junction box, which the ET4 is not. I'd leave it exactly the way is is with the possible exception of moving the GFCI outlet to the ET4 panel KO and putting a blank cover on the existing bell box. You will also need to plug the third hole from the switch box if you remove the switch. I left the switch in my installation so I can leave the light off without reprogramming if I'm going out of town for instance.
    8.5k gallon IG pebble sheen play pool with Intellitouch control, Intellifo VF, IC 20, Rainbow tab feeder (not currently in use), Pentaire mystery cartridge filter with labels faded to the point I have no idea on the model, Intellibrite 5g LED light, Hayward Navigator. Adding IntelliPh and Crestron control next.
    Jun 2012
    Phoenix, AZ
    17
    I suspected there was such a rule. I'l put a switch in the now empty outlet box too. Sounds like a good idea.
    Thanks!
