Thread: Spa / pool return actuator valve problem
    Howdy!
    I've been working on this problem for a while and can't figure it out.
    I have a compool controlled Jandy valve actuator which rotates to allow water to return to the pool or the spa.
    When I am running pool only, there are no issues, good flow, good pressure, and nothing goes to the spa, and the spa maintains it's level.
    When I turn off the pool. The spa drains to the level of the pool.
    When I turn on the spa, water flows to the spa, but also to the pool, even though the actuator has turned and the pool should be off.
    I have replaced the check valve on the spa return and have replaced the diverter valve, but still cannot seal off the pool return.
    It's more of an issue now as when I want to heat the spa, I am also heating the pool and it's taking too long.
    Any ideas appreciated, please!
    25k I G plaster pool w/spa. 2.2HP Century Centurion switchless motor. COMPOOL lx3800. Pentair FNS Plus DE FILTER 60sq/ft.
    Houston, TX - direct sunlight 8 hours a day.
    38,284
    Re: Spa / pool return actuator valve problem
    Can you add some pictures of you equipment pad and plumbing? That may help us figure out what is going on.
    22,548
    Does the valve completely close the branch to the pool off when it's switched to spa mode? Is the handle parallel with the pipe?
    I'll grab a photo now.
    Yes the handle turns the whole way and is in line with the pipe, so the pool return should be shut off. It works fine and looks the same in the opposite direction, I never get flow to the spa when running the pool.
